Oil change and now no oil pressure!
#2345759
07/30/17 04:23 PM
07/30/17 04:23 PM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
I just did an oil and filter change and now there is no oil pressure. The gauge worked just prior to the oil change. I have lots of oil in the pan. No leaks either. What should I look for?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: Oil change and now no oil pressure!
[Re: Andrewh]
#2345770
07/30/17 04:39 PM
07/30/17 04:39 PM
RapidRobert
mechanical or electrical gauge? if electrical is there any possibility a wire got bumped loose? are the lifters clattering? Lastly you might pull the filter & even cranking or starting it for several seconds to see if it is pumping (on that one hopefully a BB or a SB with the 90 deg adapter so you can put a bag over it!. holler how it goes/what it ends up being.
[Re: 500ciBee]
#2345772
07/30/17 04:45 PM
07/30/17 04:45 PM
500ciBee
Ontario, Canada
No other work done. Just oIL and filter. I put a Fram PH8A on. Car has a mechanical gauge. I let it run for 25 seconds or so and the gauge didn't move. I primed the filter before putting it on. The filter is warm to the touch.
[Re: 500ciBee]
#2345776
07/30/17 04:51 PM
07/30/17 04:51 PM
RapidRobert
To Keep It Simple Sam, it sounds like a bad filter (not sure exactly how it is plugged or partly plugging up tho). I would suggest a Wix. EDIT yes hand fill the new filter up first, as you know it'll take a few minutes for it to settle so you get it as full as you can
[Re: Andrewh]
#2345784
07/30/17 05:17 PM
07/30/17 05:17 PM
RapidRobert
^^^ this, & the warm temp sure sounds like it is partly plugged up.
[Re: 500ciBee]
#2345790
07/30/17 05:32 PM
07/30/17 05:32 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Heard this happen with Fram filters.Not saying its the problem. But I used to run them.Do not anymore. I run k&Ns on my 440.Rockyu
Chrysler Firepower
[Re: 500ciBee]
#2345794
07/30/17 05:33 PM
07/30/17 05:33 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
After changing filters, and getting pressure, cut open the fram and tell us what's wrong with it. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: perfmachst]
#2345811
07/30/17 06:10 PM
07/30/17 06:10 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
do not run past 10 seconds. damages bearings. pull dist and drive gear and turn pump with drill motor. try different gauge. I had an oil pump failure ~ 1975 on my '68 383, don't recall the mileage but well under 100,000 miles. Probably a long shot but don't overlook it either. I stupidly damaged my engine. 2ยข Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 500ciBee]
#2345812
07/30/17 06:19 PM
07/30/17 06:19 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I've heard too many horror stories on Fram filters, so never used them. Wix, then started to hear they may be producing over seas now too, not sure. Using Baldwin now.
I would definitely pull the filter to start and cut it open. That's cheap and easy, then go from there.
Facts are stubborn things.
[Re: therocks]
#2345846
07/30/17 07:29 PM
07/30/17 07:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Heard this happen with Fram filters.Not saying its the problem. But I used to run them.Do not anymore. I run k&Ns on my 440.Rockyu I know Fram's are usually junk, but I had this happen recently with a Performance K&N filter on my Trans Am's LS1, oil change/filter, no pressure, changed out filter for another K&N; presto! oil pressure...sounds like quality standards are slipping everywhere!
[Re: DAYCLONA]
#2345896
07/30/17 09:24 PM
07/30/17 09:24 PM
RapidRobert
sounds like quality standards are slipping everywhere! it is.
[Re: DAYCLONA]
#2345928
07/30/17 10:26 PM
07/30/17 10:26 PM
Posts: 15,401 Omaha Ne
TJP
Omaha Ne
myself, I say pull the distubutor and drive gear. Use a drill to run the pump ( don' forget CCW on a BB)] IF you are building pressure the drill motor will let you know via resistance. If so, and no pressure registering, Change the guage, Still no pressure ? change the filter and repeat. I would NOT START THE MOTOR AGAIN until the drill motor produces pressure PERIOD!! please report back an whether it was a filter problem or not. AGAIN, I would NOT START THE MOTOR AGAIN until the drill motor produces pressure PERIOD!!
