Re: Small Block Sidewinder Heads FULL port work pics
[Re: Prochargedmopar]
#2344915
07/28/17 05:08 PM
07/28/17 05:08 PM
BradH
So... I looked at the pic & the caption... and my very first thought was: WHY is he removing the guides on a new set of street replacement heads? Were they junk right outta the box? Is the person doing the work going to set them up for valves with thinner stems? Is this person going to port them with or without new guides in the heads? If without, how can any progress checks be tested on a flow bench when the valves can't be installed? Either I'm simply missing the rest of the story, or this porting job is starting off in a very unconventional manner.
#2344940
07/28/17 06:11 PM
07/28/17 06:11 PM
Posts: 4,206 New York
polyspheric
New York
It's how you get access to the bowl behind the guide.
Boffin Emeritus
[Re: BradH]
#2345328
07/29/17 04:21 PM
07/29/17 04:21 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Maybe he is going to put it on a cnc machine before he hand finishes the porting??
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: polyspheric]
#2345357
07/29/17 05:47 PM
07/29/17 05:47 PM
Prochargedmopar
Granbury TX
Yeah, I would think he knows a thing or two about cylinder heads.
[Re: YO7_A66]
#2345360
07/29/17 05:49 PM
07/29/17 05:49 PM
Prochargedmopar
Granbury TX
Keep us updated!! My bowl blended/port matched set of SB Sidewinders just arrived at my UPS store this morning. I will pick them up after work today. So whatcha got as a review? Like what you see?
#2345371
07/29/17 06:29 PM
07/29/17 06:29 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
So far, the quality looks very good. I do not have my head gaskets yet, so I can't move much farther except for checking my rocker arm alignment (tomorrow). It looks like stock type head bolts will work (except additional [2] 4.5" long bolts), but my spark plugs from my old iron J's do not work in these heads. So I will need to find out the type of plugs that are required. The heads have been hand-stamped with a number, so it appears that they file the info on each set of heads. The push rod holes are the same diameter as the stock heads. Comp springs/retainers and 10 degree locks.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#2345374
07/29/17 06:38 PM
07/29/17 06:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
yea, dont you worry, Larry aint no dummy...he isnt some Johnny Come lately on heads.
RIP Monte Smith
[Re: CompWedgeEngines]
#2345391
07/29/17 07:15 PM
07/29/17 07:15 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
yea, dont you worry, Larry aint no dummy...he isnt some Johnny Come lately on heads. Here's Johnny. Larry does some very nice work and you should be pleased. Goodluck on your builds
[Re: pittsburghracer]
#2345410
07/29/17 08:09 PM
07/29/17 08:09 PM
CompWedgeEngines
Syracuse,NY
LOL...I forgot we had a Johnny head guy!...lol...how you makin out?
I am gonna try to send you a PM this weekend if I get time.
RIP Monte Smith
#2345424
07/29/17 08:48 PM
07/29/17 08:48 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I am gonna try to send you a PM this weekend if I get time. Doing OK Todd but kinda took a step back from racing for a little break. Powerglide issues kicked my butt having to pull it in and out 6 times. LOL. I bought some "fishing worms" now I got to go use them.
#2345440
07/29/17 09:34 PM
07/29/17 09:34 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
When I was still doing port work, on twin cam Harley heads I would remove the guide to do my porting, was replacing them anyway, stock heads 2.12 valve & larger seats 328 cfm .650 for steet use.
[Re: CSK]
#2345444
07/29/17 09:52 PM
07/29/17 09:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does anyone know what these SB heads flow... both ported and stock... also does anyone know what the valve length is.. thanks
[Re: MR_P_BODY]
#2345454
07/29/17 10:18 PM
07/29/17 10:18 PM
YO7_A66
Indiana
The Sidewinders start with the Promaxx castings. I have attached the flow chart. Todd has them ported to the customers needs. I am waiting on the flow numbers for my bowl ported version, and Prochargedmopar is having his fully ported soon.
