Page 1 of 4 1 2 3 4
Small Block Sidewinder Heads FULL port work pics #2344873
07/28/17 03:24 PM
07/28/17 03:24 PM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
I'm thinking these will be shipped to me when done.
WoooooHooooo!
https://www.facebook.com/permalink.php?story_fbid=1120574778075029&id=503146179817895
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2344888
07/28/17 03:55 PM
07/28/17 03:55 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
up Keep us updated!!
My bowl blended/port matched set of SB Sidewinders just arrived at my UPS store this morning. I will pick them up after work today. boogie
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2344915
07/28/17 05:08 PM
07/28/17 05:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
So... I looked at the pic & the caption... and my very first thought was: WHY is he removing the guides on a new set of street replacement heads?
Were they junk right outta the box?
Is the person doing the work going to set them up for valves with thinner stems?
Is this person going to port them with or without new guides in the heads? If without, how can any progress checks be tested on a flow bench when the valves can't be installed?
Either I'm simply missing the rest of the story, or this porting job is starting off in a very unconventional manner. shruggy
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2344940
07/28/17 06:11 PM
07/28/17 06:11 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's how you get access to the bowl behind the guide.
Boffin Emeritus
Re: Small Block Sidewinder Heads FULL port work pics [Re: polyspheric] #2344980
07/28/17 07:59 PM
07/28/17 07:59 PM
BradH Offline
BradH  Offline
Or you can use the appropriately-shaped carbide burr w/ a 4-6" extended shank like 99% of the rest of the people porting heads by hand do. sawzall
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345080
07/29/17 12:50 AM
07/29/17 12:50 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess that's the poor mans "pro port" head.
Re: Small Block Sidewinder Heads FULL port work pics [Re: BradH] #2345328
07/29/17 04:21 PM
07/29/17 04:21 PM
Granbury TX
Granbury TX
Maybe he is going to put it on a cnc machine before he hand finishes the porting??
02 Mercedes C230K
19 Camry
Re: Small Block Sidewinder Heads FULL port work pics [Re: polyspheric] #2345357
07/29/17 05:47 PM
07/29/17 05:47 PM
Granbury TX
Granbury TX
Yeah,
I would think he knows a thing or two about cylinder heads.
02 Mercedes C230K
19 Camry
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345359
07/29/17 05:49 PM
07/29/17 05:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Larry Smith
Re: Small Block Sidewinder Heads FULL port work pics [Re: YO7_A66] #2345360
07/29/17 05:49 PM
07/29/17 05:49 PM
Granbury TX
Granbury TX
So whatcha got as a review?
Like what you see?
02 Mercedes C230K
19 Camry
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345371
07/29/17 06:29 PM
07/29/17 06:29 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
So far, the quality looks very good. I do not have my head gaskets yet, so I can't move much farther except for checking my rocker arm alignment (tomorrow). It looks like stock type head bolts will work (except additional [2] 4.5" long bolts), but my spark plugs from my old iron J's do not work in these heads. So I will need to find out the type of plugs that are required.
The heads have been hand-stamped with a number, so it appears that they file the info on each set of heads. The push rod holes are the same diameter as the stock heads. Comp springs/retainers and 10 degree locks.
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345374
07/29/17 06:38 PM
07/29/17 06:38 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
yea, dont you worry, Larry aint no dummy...he isnt some Johnny Come lately on heads.
RIP Monte Smith
Re: Small Block Sidewinder Heads FULL port work pics [Re: CompWedgeEngines] #2345391
07/29/17 07:15 PM
07/29/17 07:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Here's Johnny. Larry does some very nice work and you should be pleased. Goodluck on your builds
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Sidewinder Heads FULL port work pics [Re: pittsburghracer] #2345410
07/29/17 08:09 PM
07/29/17 08:09 PM
Syracuse,NY
Syracuse,NY
LOL...I forgot we had a Johnny head guy!...lol...how you makin out?
I am gonna try to send you a PM this weekend if I get time.
RIP Monte Smith
Re: Small Block Sidewinder Heads FULL port work pics [Re: CompWedgeEngines] #2345424
07/29/17 08:48 PM
07/29/17 08:48 PM
PA.
"Little"John
"Little"John
PA.
Doing OK Todd but kinda took a step back from racing for a little break. Powerglide issues kicked my butt having to pull it in and out 6 times. LOL. I bought some "fishing worms" now I got to go use them.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345440
07/29/17 09:34 PM
07/29/17 09:34 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
When I was still doing port work, on twin cam Harley heads I would remove the guide to do my porting, was replacing them anyway, stock heads 2.12 valve & larger seats 328 cfm .650 for steet use.
Re: Small Block Sidewinder Heads FULL port work pics [Re: CSK] #2345444
07/29/17 09:52 PM
07/29/17 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does anyone know what these SB heads flow...
both ported and stock... also does anyone know
what the valve length is.. thanks
wave
Re: Small Block Sidewinder Heads FULL port work pics [Re: MR_P_BODY] #2345454
07/29/17 10:18 PM
07/29/17 10:18 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The Sidewinders start with the Promaxx castings. I have attached the flow chart.
Todd has them ported to the customers needs. I am waiting on the flow numbers for my bowl ported version, and Prochargedmopar is having his fully ported soon.
Attached PDF document
sbmoparflow171.pdf (459 downloads)
Re: Small Block Sidewinder Heads FULL port work pics [Re: YO7_A66] #2345467
07/29/17 10:43 PM
07/29/17 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Re: Small Block Sidewinder Heads FULL port work pics [Re: Prochargedmopar] #2345549
07/30/17 02:09 AM
07/30/17 02:09 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Given the reasonable $ on used NASCAR 7mm Ti valves, I've been putting new guides (and sometimes seats) in a lot of heads.
Now I just need to find a guy with one of those Newen single point valve machines to adopt me, lol. S/F....Ken M
Page 1 of 4 1 2 3 4
