MP 90 Degree Oil Filter Mount Gaskets #2340566
07/20/17 09:43 PM
07/20/17 09:43 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Does anyone know the correct thicknesses of the gaskets for the MP 90 Degree oil fiter mount?
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2340730
07/21/17 12:39 AM
07/21/17 12:39 AM
reportedly the felpro "single' round gasket #70078 is a hair thicker than the single round gasket in the MP 3 piece kit. I have one (not sure which, MP or FP) that I will mike tomorrow. either would (should) work fine for you & a caveat is to clean the recessed block circular recess squeaky clean & to use some cement to hold the gasket in place as you raise the adapter up in place & to have it clocked correctly as you raise it so that you dont have to rotate it after "contact" is made. Leak issue I am assuming? EDIT Oh you needed the thickness of the thick cork one that goes on the big bolt inside the housing and the thin one that goes under the bolt head.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2340789
07/21/17 03:02 AM
07/21/17 03:02 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looks like the thick cork gasket is about .175" thick. The P5249320 kit with all 3 pieces is still available.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2340818
07/21/17 08:14 AM
07/21/17 08:14 AM
STEFF Offline OP
STEFF  Offline OP
Yeah, if you can measure them, that would be great. Thanx Guys!
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2340863
07/21/17 11:01 AM
07/21/17 11:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Steff, Superformance sell the gasket sets for the adapter. I have a couple sets if you need measurements let me know.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2340909
07/21/17 12:22 PM
07/21/17 12:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I used to have those gaskets in my file cabinet, in 2013...hope you get the dimension needed
Rich H.
Esse Quam Videri
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2341099
07/21/17 07:08 PM
07/21/17 07:08 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Superformance #340-K1
Inner cork & rubber gasket .195"
Outer fiber washer .062"
Large housing gasket .047"
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: roadhazard] #2341114
07/21/17 07:37 PM
07/21/17 07:37 PM
Mine is .089" but I do not know what brand it is.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: roadhazard] #2341117
07/21/17 07:40 PM
07/21/17 07:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
This kit works GREAT.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2341136
07/21/17 08:18 PM
07/21/17 08:18 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I don`t know if you are having a sealing problem or not but make sure the bolt is not too long. I had one that came in the kit that was a little long. It was not allowing me to get the adapter tight enough even though the bolt felt plenty tight.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2341227
07/21/17 11:03 PM
07/21/17 11:03 PM
STEFF Offline OP
STEFF  Offline OP
Thanx Guys! Picked up the Superformance gaskets kit from Marsh Performance today.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2341242
07/21/17 11:16 PM
07/21/17 11:16 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Don't know what the reason was behind your original question but if you have any about what you're receiving give me a call.
Thanks for your support STEFF thumbs
(and pittsburghracer smile )
p.s...... if you need to retain the large gasket in the block don't use any adhesives, a couple dabs of grease would do you right.
Re: MP 90 Degree Oil Filter Mount Gaskets [Re: STEFF] #2341301
07/22/17 12:52 AM
07/22/17 12:52 AM
STEFF Offline OP
STEFF  Offline OP
My Son's Duster was leaking and we didnt want to wait a few days for a new gasket set to be mail ordered from anyone. So, we were just going to cut one out of gasket material. But, luckily Marsh Perf. had some in stock and I was near them today. So, I stopped by and got one. It all worked out. I also picked up a few sets of your carb gaskets too.
