Re: MP 90 Degree Oil Filter Mount Gaskets
[Re: STEFF]
#2340730
07/21/17 12:39 AM
07/21/17 12:39 AM
RapidRobert
reportedly the felpro "single' round gasket #70078 is a hair thicker than the single round gasket in the MP 3 piece kit. I have one (not sure which, MP or FP) that I will mike tomorrow. either would (should) work fine for you & a caveat is to clean the recessed block circular recess squeaky clean & to use some cement to hold the gasket in place as you raise the adapter up in place & to have it clocked correctly as you raise it so that you dont have to rotate it after "contact" is made. Leak issue I am assuming? EDIT Oh you needed the thickness of the thick cork one that goes on the big bolt inside the housing and the thin one that goes under the bolt head.
[Re: STEFF]
#2340789
07/21/17 03:02 AM
07/21/17 03:02 AM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Looks like the thick cork gasket is about .175" thick. The P5249320 kit with all 3 pieces is still available.
[Re: STEFF]
#2340909
07/21/17 12:22 PM
07/21/17 12:22 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
I used to have those gaskets in my file cabinet, in 2013...hope you get the dimension needed
Rich H.
Esse Quam Videri
[Re: roadhazard]
#2341114
07/21/17 07:37 PM
07/21/17 07:37 PM
RapidRobert
Mine is .089" but I do not know what brand it is.
[Re: roadhazard]
#2341117
07/21/17 07:40 PM
07/21/17 07:40 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Superformance #340-K1
Inner cork & rubber gasket .195" Outer fiber washer .062" Large housing gasket .047"
This kit works GREAT.
[Re: STEFF]
#2341242
07/21/17 11:16 PM
07/21/17 11:16 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Don't know what the reason was behind your original question but if you have any about what you're receiving give me a call. Thanks for your support STEFF (and pittsburghracer ) p.s...... if you need to retain the large gasket in the block don't use any adhesives, a couple dabs of grease would do you right.
