69 alternator
#2338154
07/17/17 01:30 AM
07/17/17 01:30 AM
Posts: 263 gretna, Ne
oem6pak
gretna, Ne
What's the correct #'s for an alternator in a 69 340 swinger? And where can I find 1?
Pure Stock Rules
Re: 69 alternator
[Re: oem6pak]
#2338320
07/17/17 12:49 PM
07/17/17 12:49 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
What's the correct #'s for an alternator in a 69 340 swinger? And where can I find 1? You probably need to refer to your broadcast sheet to know the EXACT part number that was used.
Re: 69 alternator
[Re: oem6pak]
#2338445
07/17/17 04:13 PM
07/17/17 04:13 PM
oem6pak
gretna, Ne
Looked at the broadcast sheet, it gives no info on alt
Pure Stock Rules
Re: 69 alternator
[Re: oem6pak]
#2338957
07/18/17 11:38 AM
07/18/17 11:38 AM
Morty426
Sacramento CA
Looked at the broadcast sheet, it gives no info on alt Not sure. The F series (1970) sheet had a code between inlet hose and fan for the alt. Maybe Mr Dan can enlighten us
Re: 69 alternator
[Re: oem6pak]
#2339512
07/19/17 02:55 AM
07/19/17 02:55 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Alternator is the first item in line 7 of the E series 1969 broadcast sheet. The bottom of your photo shows line 6.
Re: 69 alternator
[Re: oem6pak]
#2339527
07/19/17 05:12 AM
07/19/17 05:12 AM
oem6pak
gretna, Ne
It's got nothing there-blank
Pure Stock Rules
Re: 69 alternator
[Re: blewbyu]
#2340639
07/20/17 11:07 PM
07/20/17 11:07 PM
Posts: 2,253 New York
rarefish
New York
Here is an original never been apart or re manufactured 22 week of 69 which is May 14 of 1969. It is all original with correct sunburst and original rear bearing where my finger is pointing. This is spot on for your car with a SPD of 609. Check you Pm Box. I just checked my original alternator from my 69 340 Dart and it's also shows the part number 2642537
Re: 69 alternator
[Re: rarefish]
#2340656
07/20/17 11:22 PM
07/20/17 11:22 PM
Posts: 4,283 Florida
blewbyu
Here is an original never been apart or re manufactured 22 week of 69 which is May 14 of 1969. It is all original with correct sunburst and original rear bearing where my finger is pointing. This is spot on for your car with a SPD of 609. Check you Pm Box. I just checked my original alternator from my 69 340 Dart and it's also shows the part number 2642537 Whats your SPD and what date code is on your alt.? Thanks
