Page 1 of 2 1 2 >
#2338154 - 07/16/17 11:30 PM 69 alternator
oem6pak Offline
Loc: gretna, Ne
What's the correct #'s for an alternator in a 69 340 swinger? And where can I find 1?
Pure Stock Rules
#2338222 - 07/17/17 08:21 AM Re: 69 alternator [Re: oem6pak]
blewbyu Offline
Loc: Florida
What combo do you have , non A/C or A/C? If you want a correct date code build date required also. I sent you a Pm.
#2338320 - 07/17/17 10:49 AM Re: 69 alternator [Re: oem6pak]
Morty426 Offline
Loc: Sacramento CA
You probably need to refer to your broadcast sheet to know the EXACT part number that was used.
#2338419 - 07/17/17 01:40 PM Re: 69 alternator [Re: oem6pak]
oem6pak Offline
Loc: gretna, Ne
Thx,I'll look
Pure Stock Rules
#2338445 - 07/17/17 02:13 PM Re: 69 alternator [Re: oem6pak]
oem6pak Offline
Loc: gretna, Ne
Looked at the broadcast sheet, it gives no info on alt
Edited by oem6pak (07/17/17 02:14 PM)
Edit Reason: Info
Pure Stock Rules
#2338469 - 07/17/17 02:49 PM Re: 69 alternator [Re: oem6pak]
BigMoneyLewis Offline
Loc: Alabama
Your broadcast sheet should give you the last 2 digits of the part number, then look it up in Galen's book, that will give you the full 7 digit number .
Greg
gregward@mchsi.com phone 256-852-0955
#2338885 - 07/18/17 02:53 AM Re: 69 alternator [Re: oem6pak]
oem6pak Offline
Loc: gretna, Ne
Here it is
Pure Stock Rules
#2338957 - 07/18/17 09:38 AM Re: 69 alternator [Re: oem6pak]
Morty426 Offline
Loc: Sacramento CA
Not sure. The F series (1970) sheet had a code between inlet hose and fan for the alt.
Maybe Mr Dan can enlighten us
#2339020 - 07/18/17 10:59 AM Re: 69 alternator [Re: oem6pak]
JRepucci Offline
Loc: Sacramento,California
A 340, auto, non/air would have a 2642537
My 707 SPD 340 Dart... original alternator
#2339219 - 07/18/17 03:17 PM Re: 69 alternator [Re: JRepucci]
oem6pak Offline
Loc: gretna, Ne
Thank you
Pure Stock Rules
#2339399 - 07/18/17 09:04 PM Re: 69 alternator [Re: oem6pak]
blewbyu Offline
Loc: Florida
Here is an original never been apart or re manufactured 22 week of 69 which is May 14 of 1969. It is all original with correct sunburst and original rear bearing where my finger is pointing. This is spot on for your car with a SPD of 609. Check you Pm Box.
#2339512 - 07/19/17 12:55 AM Re: 69 alternator [Re: oem6pak]
kentj340 Offline
Loc: Houston
Alternator is the first item in line 7 of the E series 1969 broadcast sheet. The bottom of your photo shows line 6.
#2339527 - 07/19/17 03:12 AM Re: 69 alternator [Re: oem6pak]
oem6pak Offline
Loc: gretna, Ne
It's got nothing there-blank
Pure Stock Rules
#2339564 - 07/19/17 07:59 AM Re: 69 alternator [Re: oem6pak]
blewbyu Offline
Loc: Florida
I search for 5 years to find a correct date code Alternator for my 69 Dart. Most have been rebuilt and blasted so much you can not read them. I just sent my 2642537 12 69 out to be restored. It was also a unrestored one with original brg. The restoration shop was impressed that I even found one unmolested. up
#2339776 - 07/19/17 01:44 PM Re: 69 alternator [Re: oem6pak]
Southern Wolf Offline
Loc: SC
I bought one last year with the correct date for my 69 GTS. I paid $300 for it. They are not cheap!
#2340639 - 07/20/17 09:07 PM Re: 69 alternator [Re: blewbyu]
rarefish Offline
Loc: New York
I just checked my original alternator from my 69 340 Dart and it's also shows the part number 2642537
#2340656 - 07/20/17 09:22 PM Re: 69 alternator [Re: rarefish]
blewbyu Offline
Loc: Florida
Whats your SPD and what date code is on your alt.?
#2340861 - 07/21/17 08:58 AM Re: 69 alternator [Re: blewbyu]
rarefish Offline
Loc: New York
Here is a pic of the alternator. The SPD is 1/27
#2341038 - 07/21/17 02:57 PM Re: 69 alternator [Re: rarefish]
blewbyu Offline
Loc: Florida
Thanks for posting. I am always keeping track of date codes compared to SPD dates. up
#2341079 - 07/21/17 04:14 PM Re: 69 alternator [Re: oem6pak]
rarefish Offline
Loc: New York
I took a look at my broadcast sheet and I'm not seeing any alternator listing part number info. I think the 70 and later sheets had them on there.
Page 1 of 2 1 2 >
25,260 Registered Members
189,048 Topics
Gear vendors electronic speed sensor
by DGS
04/27/18 04:05 AM
Drag radials, adjustable suspension, manual transmission.
by OhioMopar
04/27/18 04:01 AM
WIW complete ac system from /6 71 Duster?
by moparjoe360.4
04/27/18 01:03 AM
Anyone using the Trans-Dapt /6 to smallblock v8 swap mounts
by moparjoe360.4
04/27/18 12:22 AM
