69 alternator #2338154
07/17/17 01:30 AM
07/17/17 01:30 AM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
What's the correct #'s for an alternator in a 69 340 swinger? And where can I find 1?
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2338222
07/17/17 10:21 AM
07/17/17 10:21 AM
blewbyu Offline
blewbyu  Offline
What combo do you have , non A/C or A/C? If you want a correct date code build date required also. I sent you a Pm.
Re: 69 alternator [Re: oem6pak] #2338320
07/17/17 12:49 PM
07/17/17 12:49 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You probably need to refer to your broadcast sheet to know the EXACT part number that was used.
Re: 69 alternator [Re: oem6pak] #2338419
07/17/17 03:40 PM
07/17/17 03:40 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Thx,I'll look
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2338445
07/17/17 04:13 PM
07/17/17 04:13 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Looked at the broadcast sheet, it gives no info on alt
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2338469
07/17/17 04:49 PM
07/17/17 04:49 PM
Alabama
BigMoneyLewis Offline
Alabama
Your broadcast sheet should give you the last 2 digits of the part number, then look it up in Galen's book, that will give you the full 7 digit number .
Greg
gregward@mchsi.com phone 256-852-0955
Re: 69 alternator [Re: oem6pak] #2338885
07/18/17 04:53 AM
07/18/17 04:53 AM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Here it is
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2338957
07/18/17 11:38 AM
07/18/17 11:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Not sure. The F series (1970) sheet had a code between inlet hose and fan for the alt.
Maybe Mr Dan can enlighten us
Re: 69 alternator [Re: oem6pak] #2339020
07/18/17 12:59 PM
07/18/17 12:59 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
A 340, auto, non/air would have a 2642537
My 707 SPD 340 Dart... original alternator
Re: 69 alternator [Re: JRepucci] #2339219
07/18/17 05:17 PM
07/18/17 05:17 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Thank you
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2339399
07/18/17 11:04 PM
07/18/17 11:04 PM
blewbyu Offline
blewbyu  Offline
Here is an original never been apart or re manufactured 22 week of 69 which is May 14 of 1969. It is all original with correct sunburst and original rear bearing where my finger is pointing. This is spot on for your car with a SPD of 609. Check you Pm Box.
Re: 69 alternator [Re: oem6pak] #2339512
07/19/17 02:55 AM
07/19/17 02:55 AM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
Alternator is the first item in line 7 of the E series 1969 broadcast sheet. The bottom of your photo shows line 6.
Re: 69 alternator [Re: oem6pak] #2339527
07/19/17 05:12 AM
07/19/17 05:12 AM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
It's got nothing there-blank
Pure Stock Rules
Re: 69 alternator [Re: oem6pak] #2339564
07/19/17 09:59 AM
07/19/17 09:59 AM
blewbyu Offline
blewbyu  Offline
I search for 5 years to find a correct date code Alternator for my 69 Dart. Most have been rebuilt and blasted so much you can not read them. I just sent my 2642537 12 69 out to be restored. It was also a unrestored one with original brg. The restoration shop was impressed that I even found one unmolested. up
Re: 69 alternator [Re: oem6pak] #2339776
07/19/17 03:44 PM
07/19/17 03:44 PM
SC
Southern Wolf Offline
SC
I bought one last year with the correct date for my 69 GTS. I paid $300 for it. They are not cheap!
Re: 69 alternator [Re: blewbyu] #2340639
07/20/17 11:07 PM
07/20/17 11:07 PM
New York
rarefish Offline
rarefish  Offline
New York
I just checked my original alternator from my 69 340 Dart and it's also shows the part number 2642537
Re: 69 alternator [Re: rarefish] #2340656
07/20/17 11:22 PM
07/20/17 11:22 PM
blewbyu Offline
blewbyu  Offline
Whats your SPD and what date code is on your alt.?
Re: 69 alternator [Re: blewbyu] #2340861
07/21/17 10:58 AM
07/21/17 10:58 AM
New York
rarefish Offline
rarefish  Offline
New York
Here is a pic of the alternator. The SPD is 1/27
Re: 69 alternator [Re: rarefish] #2341038
07/21/17 04:57 PM
07/21/17 04:57 PM
blewbyu Offline
blewbyu  Offline
Thanks for posting. I am always keeping track of date codes compared to SPD dates. up
Re: 69 alternator [Re: oem6pak] #2341079
07/21/17 06:14 PM
07/21/17 06:14 PM
New York
rarefish Offline
rarefish  Offline
New York
I took a look at my broadcast sheet and I'm not seeing any alternator listing part number info. I think the 70 and later sheets had them on there.
