Thoughts on oil changes, hot oil vs cold. #2336073
07/12/17 06:37 PM
07/12/17 06:37 PM
jersey
Spaceman Spiff Offline OP
jersey
anyone see a benefit of doing an oil change a specific way? hot oil vs cold oil?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336077
07/12/17 06:41 PM
07/12/17 06:41 PM
there just was a thread on this but I don't remember the jist of it.
Re: Thoughts on oil changes, hot oil vs cold. [Re: RapidRobert] #2336086
07/12/17 06:53 PM
07/12/17 06:53 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I've always changed it hot. Just always thought you would get
more complete drainage.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336098
07/12/17 07:23 PM
07/12/17 07:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Changing it cold can allow and solids in suspension to settle out and remain to recontaminate the new oil.
Not to mention hot oil flows better.
Don't be the exception.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336102
07/12/17 07:27 PM
07/12/17 07:27 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I prefer lukewarm. Shaken, not stirred.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336103
07/12/17 07:27 PM
07/12/17 07:27 PM
P
Porter67 Offline
Porter67  Offline
P
Its all about the vw factor.
If you shut it down hot, how long do you wait to pull the plug?
If you drain it cold, you get all the rewards of all the heat thinning the oil, gravity draining and time as well.
I will break the filter loose and the plug while hot and pull the plug when cool, dump 1/2 qt in the top to flush the pan a bit and thats about all I can do.
If its a real busy time in my life, it just dont matter and the fact is I still changed the oil.
But really anyway one does it, is it really going to matter in the end?
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336137
07/12/17 08:16 PM
07/12/17 08:16 PM
BDW Offline
BDW  Offline
Some of the pics are gone because of Photobucket but this cures the hot oil problem
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1380008/1.html
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336145
07/12/17 08:38 PM
07/12/17 08:38 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Hot, but not blazing "if you touch the dipstick it's like napalm" hot.
Only because it seems to drain a whole lot faster.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336178
07/12/17 09:56 PM
07/12/17 09:56 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I like burning the crap out of my hand when I pull the drain plug, so...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336185
07/12/17 10:17 PM
07/12/17 10:17 PM
Andrewh Offline
Andrewh  Offline
I have always changed mine cold.
never had an oil related issue.
my cars die of other causes.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336217
07/12/17 11:00 PM
07/12/17 11:00 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
The worst is when one takes the car to the dealer or elsewhere for an oil change and it sits for a few hours before pulled in onto the rack.
The engine is cold as is the oil, the tech removes the drain plug and lets oil run for a couple of minutes and replaces the plug.
Adds 5 quarts of oil to a 6 quart capacity pan and calls it a day.
Or possibly worse, puts in the recommended 6 quarts
What could go wrong?
Re: Thoughts on oil changes, hot oil vs cold. [Re: Sxrxrnr] #2336220
07/12/17 11:04 PM
07/12/17 11:04 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
He could forget to put the plug back in, or close the valve it it has that fancy valve. He could forget to put in oil, or the wrong oil. He might or might not replace the filter. work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336232
07/12/17 11:14 PM
07/12/17 11:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The only substantive case I can make here is, drain it hot while anything in the oil is still suspended, but let drain for awhile to get as much oil drained as possible, I go like 1/2hr, and its still dripping, talking about the oil. drumhit
Re: Thoughts on oil changes, hot oil vs cold. [Re: jcc] #2336293
07/13/17 12:36 AM
07/13/17 12:36 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Usually cold.
I always figured with it cold, the oil had time to drain back to the pan from the upper extremes of the engine giving a more complete drain.
Rarely am I in a rush, so, I'll pull the plug and let gravity do its thing for a half hour or longer.
I've always done it this way and have never had an issue.
John
Re: Thoughts on oil changes, hot oil vs cold. [Re: Porter67] #2336330
07/13/17 01:47 AM
07/13/17 01:47 AM
good idea that I have wondered about for awhile & recently I had oil pan out/leveled (tho most are changed with the front jacked up) I was surprised at the amt of dirty oil left in the bottom (& extended oil changes are getting more common).
Re: Thoughts on oil changes, hot oil vs cold. [Re: RapidRobert] #2336334
07/13/17 01:58 AM
07/13/17 01:58 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I drain mine after work on Friday evening when the motor is still warm, but not hot, and let it drip all night. Next morning I pull the filter off, and because all the oil has settled it doesn't run on me, and put a new one on and start adding new oil.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Neil] #2336480
07/13/17 01:46 PM
07/13/17 01:46 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I researched this years ago and the hot oil change was the best ( as said above) because the "contaminants are held in suspension and drain out with the oil"..
Re: Thoughts on oil changes, hot oil vs cold. [Re: floridian] #2336498
07/13/17 02:23 PM
07/13/17 02:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Surprised nobody has mentioned, I also use a qt of generic "oil change flush" additive nearly every oil change, with my typical longer then average intervals. It's probably the most expensive off road red dyed diesel fuel one can buy. laugh2
Re: Thoughts on oil changes, hot oil vs cold. [Re: jcc] #2336560
07/13/17 04:50 PM
07/13/17 04:50 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
It's also impossible to get all the oil out of the engine as the drain bolt hole is either too high up on the pan, or if it's on the bottom any oil from the top of the stove nut on down won't come out. I guess you could jack the car up, or rock it back and forth to help slosh a bit more out.
Re: Thoughts on oil changes, hot oil vs cold. [Re: Spaceman Spiff] #2336572
07/13/17 05:05 PM
07/13/17 05:05 PM
Washington/Las Vegas
1971 Gran Coupe Offline
If sediment is a major concern, I would think seriously on a better filter. Not sure what most are rated at, but I believe it is only a few microns that is allowed to pass through the filter.
I usually change it fairly warm, and not hot. Cold, it takes forever for the last drop to drip. wrench
