Thoughts on oil changes, hot oil vs cold.
#2336073
07/12/17 06:37 PM
07/12/17 06:37 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
anyone see a benefit of doing an oil change a specific way? hot oil vs cold oil?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Thoughts on oil changes, hot oil vs cold.
[Re: Spaceman Spiff]
#2336077
07/12/17 06:41 PM
07/12/17 06:41 PM
RapidRobert
there just was a thread on this but I don't remember the jist of it.
#2336098
07/12/17 07:23 PM
07/12/17 07:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Changing it cold can allow and solids in suspension to settle out and remain to recontaminate the new oil.
Not to mention hot oil flows better.
#2336178
07/12/17 09:56 PM
07/12/17 09:56 PM
Posts: 3,416 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I like burning the crap out of my hand when I pull the drain plug, so...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
#2336217
07/12/17 11:00 PM
07/12/17 11:00 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
The worst is when one takes the car to the dealer or elsewhere for an oil change and it sits for a few hours before pulled in onto the rack.
The engine is cold as is the oil, the tech removes the drain plug and lets oil run for a couple of minutes and replaces the plug.
Adds 5 quarts of oil to a 6 quart capacity pan and calls it a day.
Or possibly worse, puts in the recommended 6 quarts
What could go wrong?
[Re: Sxrxrnr]
#2336220
07/12/17 11:04 PM
07/12/17 11:04 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
He could forget to put the plug back in, or close the valve it it has that fancy valve. He could forget to put in oil, or the wrong oil. He might or might not replace the filter.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: jcc]
#2336293
07/13/17 12:36 AM
07/13/17 12:36 AM
Posts: 16,894 Between Houston & Galveston TX
SattyNoCar
Usually cold.
I always figured with it cold, the oil had time to drain back to the pan from the upper extremes of the engine giving a more complete drain.
Rarely am I in a rush, so, I'll pull the plug and let gravity do its thing for a half hour or longer.
I've always done it this way and have never had an issue.
John
[Re: Porter67]
#2336330
07/13/17 01:47 AM
07/13/17 01:47 AM
RapidRobert
dump 1/2 qt in the top to flush the pan a bit and thats about all I can do. good idea that I have wondered about for awhile & recently I had oil pan out/leveled (tho most are changed with the front jacked up) I was surprised at the amt of dirty oil left in the bottom (& extended oil changes are getting more common).
