Re: 3rd time is a go for 511 install
[Re: mopar dave]
#2332674
07/06/17 06:29 PM
07/06/17 06:29 PM
Posts: 326 Alberta
Wookie316
Alberta
That is the one nice thing about running a B body tank like mine, you just put the motor in and go! I just need to loose 800 pounds LOL. Once you are done fitting, the final result will be more than worth the effort I am sure. Can't wait to see pictures of finished product. Thanks for sharing.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: AndyF]
#2332811
07/06/17 11:17 PM
07/06/17 11:17 PM
dartman366
Mt. Vernon, Ohio
My engine plates put the engine where TTI wants it. That is the whole idea of using my pre-machined plates. They are designed to match the TTI drawing so the engine is where it needs to be for the headers to fit. You had the engine plate on backwards which is why you had so much trouble. Don't feel bad Dave, I did the same thing and had to flip the plate around myself.
[Re: AndyF]
#2332818
07/06/17 11:35 PM
07/06/17 11:35 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
My engine plates put the engine where TTI wants it. That is the whole idea of using my pre-machined plates. They are designed to match the TTI drawing so the engine is where it needs to be for the headers to fit. You had the engine plate on backwards which is why you had so much trouble. How about giving him some measurements!Like pulling teeth around here.
