Re: 3rd time is a go for 511 install [Re: mopar dave] #2332647
07/06/17 05:43 PM
07/06/17 05:43 PM
In the past when we used elephant ears and or a front motor plate in a non stock BB A body we would position the motor where we wanted it front to rear, left to right and up or down) with the headers and trans mount bolted down and then weld the angle iron onto the front sub frames to bolt the motor plate to work up
Re: 3rd time is a go for 511 install [Re: Clanton] #2332660
07/06/17 06:07 PM
07/06/17 06:07 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Pass side header went on no problem. 1" or more clearance.
Re: 3rd time is a go for 511 install [Re: Cab_Burge] #2332662
07/06/17 06:11 PM
07/06/17 06:11 PM
Mt Morris Michigan
Mt Morris Michigan
Thats kind of what im doing. Trans is bolted up with slotted t mount. Used one schumacher conversion mount on pass side to locate but its tight. Trans dip stick is tight against firewall. I think it needs to move forward and to past side a bit more.
Re: 3rd time is a go for 511 install [Re: mopar dave] #2332674
07/06/17 06:29 PM
07/06/17 06:29 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
That is the one nice thing about running a B body tank like mine, you just put the motor in and go! I just need to loose 800 pounds LOL.
Once you are done fitting, the final result will be more than worth the effort I am sure. Can't wait to see pictures of finished product.
Thanks for sharing.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 3rd time is a go for 511 install [Re: Wookie316] #2332767
07/06/17 10:09 PM
07/06/17 10:09 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks. Hard to find the extra time to work on ot, so its slow going. Should be done soon.
Re: 3rd time is a go for 511 install [Re: Cab_Burge] #2332769
07/06/17 10:12 PM
07/06/17 10:12 PM
Mt Morris Michigan
Mt Morris Michigan
So cab, should the engine plate be centered or tight to the pass side inner fender when properly located?
Re: 3rd time is a go for 511 install [Re: mopar dave] #2332781
07/06/17 10:41 PM
07/06/17 10:41 PM
Tt's your choice on where YOU want it up
I used a motor plate on my Duster and slid the motor back and made sure it was as far as I could get it over to the right side(passenger side) for maximum weight on that side and still get to the spark plugs easily with the hooker 2.0 inch fender well headers to offset my body weight in the drivers seat up scope
I slotted the trans mount to slide the motor and tranny back as far as I could get it and still get the passenger side valve cover off without hitting the stock firewall, I had to remove a little more of the fender wells to clear the headers also on sliding it back shruggy
Once I had it where I wanted it located I had the front angle iron tabs welded onto the top of the sub frames and then drilled the two 3/8 inch holes on each side to bolt it down. I did have the motor plate sitting behind the tabs also thumbs
That car ended up with me in the driver seat on having 49 3/4 % on the rear tires and 50 1/4% total car weight on the fronts boogie devil
Re: 3rd time is a go for 511 install [Re: mopar dave] #2332798
07/06/17 11:07 PM
07/06/17 11:07 PM
AndyF Offline
AndyF  Offline
My engine plates put the engine where TTI wants it. That is the whole idea of using my pre-machined plates. They are designed to match the TTI drawing so the engine is where it needs to be for the headers to fit. You had the engine plate on backwards which is why you had so much trouble.
Re: 3rd time is a go for 511 install [Re: AndyF] #2332811
07/06/17 11:17 PM
07/06/17 11:17 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Don't feel bad Dave, I did the same thing and had to flip the plate around myself.
Re: 3rd time is a go for 511 install [Re: AndyF] #2332812
07/06/17 11:17 PM
07/06/17 11:17 PM
Mt Morris Michigan
Mt Morris Michigan
Andy why is the nice semi polished side of your engine plate suppose to face the engine and the dull side with purple ink stampings face the radiator. thats where i went wrong. just thought the nice side should face forward.
Re: 3rd time is a go for 511 install [Re: Cab_Burge] #2332815
07/06/17 11:29 PM
07/06/17 11:29 PM
Mt Morris Michigan
Mt Morris Michigan
Cab, i cant go back any further as the trans dipstick tube is tight against the firewall and looking at the steering box and engine in its current position i think it needs to go forward a bit for headers to fit. Also having drag link oil pan cleance issues with the moroso pan you sold me awhile back. just on the outer edges. It will turn almost lock to lock but hits the pan. normal?
Re: 3rd time is a go for 511 install [Re: AndyF] #2332818
07/06/17 11:35 PM
07/06/17 11:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How about giving him some measurements!Like pulling teeth around here.
Re: 3rd time is a go for 511 install [Re: Clanton] #2332839
07/07/17 12:01 AM
07/07/17 12:01 AM
Mt Morris Michigan
Mt Morris Michigan
according to hughes engines site the engine needs to sit 1.375" toward pass from center. i'm still going to use the schumacher motor mount on pass side to help locate engine in proper location, makes headers easier fit. Maddog headers fit real nice on pass side. had them in and bolted up in about 10 minutes.
Re: 3rd time is a go for 511 install [Re: dartman366] #2332844
07/07/17 12:04 AM
07/07/17 12:04 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, [censored] happens i guess. ordered another plate. should be here next week. i had holes drilled for coil and such, wont look right if i flip it around.
Re: 3rd time is a go for 511 install [Re: mopar dave] #2332851
07/07/17 12:19 AM
07/07/17 12:19 AM
owasso ok
V
vindicator Offline
vindicator  Offline
V
owasso ok
I also thought the motor plate should have had the nice side with the logo facing forward, but it went up against the motor facing the rear of the car and the dull side with ink markings faced out.
I just figured our Duster is so ugly Andy didn't want anyone to know it was his.
Re: 3rd time is a go for 511 install [Re: vindicator] #2332859
07/07/17 12:31 AM
07/07/17 12:31 AM
Mt Morris Michigan
Mt Morris Michigan
I know, its ass backwards. I would think they would like the logo/nice side facing forward.
