Re: 3rd time is a go for 511 install
[Re: mopar dave]
#2332171
07/05/17 10:14 PM
07/05/17 10:14 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
As already mentioned, just cut a wrench down and you're good to go. Do the headers clear everything on both sides?
[Re: mopar dave]
#2332492
07/06/17 01:48 PM
07/06/17 01:48 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
You can go ahead and measure the offset and see where that is going to put the engine and this may give you more questions while you are waiting to hear from him. ps:measure the length of the tabs and will they hit in the other direction and as is now if flipped will it hit the uca area?Are they even on both sides now?o/c of the crank what is the offset frame to frame?How far above is the oil pan from the k frame?
[Re: mopar dave]
#2332589
07/06/17 04:22 PM
07/06/17 04:22 PM
Thumperdart
State of confusion
For sure Dom. Been workin alot of hrs and been moving last 2 wks. Just finished today. Moving sucks Life can get in the way for sure but, we just keep going forward till our goals are met or EXCEEDED............
[Re: mopar dave]
#2332606
07/06/17 04:43 PM
07/06/17 04:43 PM
Clanton
northern,Ohio,USA
Oil pan is 1/2" above K and o/c to pass side about a 1/2". I think it needs to be 1.375 Thank you for the reply,I don't mean to be a pita.You may be able to check the offset on the trans mount to match to the engine.Will the engine plate let you do that?Can you get to the oil pan bolts with it that close?
