Re: 69 A body rear shackles keep snapping
[Re: mikemee1331]
#2331550
07/04/17 08:12 PM
07/04/17 08:12 PM
Posts: 141 Ohio, USA
Donny
Ohio, USA
i've never had the bolt snap and can't figure out how that could happen. i have had them come loose from the press fit but even that is more annoying than anything else. are you sure the bushings are the right ones? All the parts are correct, I'm wondering if it is defective cheap parts possibly made in China. This has all happened during assembly with no weight of the car on the suspension yet, so that scares me a bit.
[Re: Donny]
#2331557
07/04/17 08:42 PM
07/04/17 08:42 PM
RapidRobert
for peace of mind I would get a used set in there & chase/torque the threads. EDIT used original set I neglected to say.
[Re: buildanother]
#2331646
07/04/17 11:35 PM
07/04/17 11:35 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Most off these use a mechanical lock nut and don't need to be very tight. I just use an open end wrench to tighten them and that is all you need. Once the nut stops against the shackle STOP TIGHTENING IT or you will snap it off. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2331693
07/05/17 12:40 AM
07/05/17 12:40 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
I just use an open end wrench to tighten them and that is all you need. Once the nut stops against the shackle STOP TIGHTENING IT or you will snap it off. Gus The A body thread size is a lot smaller than the B and E body size hangars, don't use the wrong torque specs.
[Re: Cab_Burge]
#2331699
07/05/17 12:52 AM
07/05/17 12:52 AM
RapidRobert
^ agreed, all I do is A bodies & the diameter of the short threaded end of the shank is pretty small.
