Re: Question about Trans Brake
[Re: TomsCharger70]
#2330353
07/02/17 08:56 PM
07/02/17 08:56 PM
Posts: 1,030 ohio
67mprfan
ohio
Is the front pump drilled
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: J_BODY]
#2330657
07/03/17 01:15 PM
07/03/17 01:15 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
I've always ran Griners, but currently have a Pro Trans clean N piece. Cope makes brakes now too. Is your torque converter built for T-brake usage? what rear end, and driveline? ...and what axles? I'd want 35 spline for sure. -The converter is a brand new one from Ultimate, and no, I did not spec it out for transbrake use... Stall is +5000rpm. -Rear axel is a Dana 60 (Dr. Diff/Strange). Detroit Locker, 4.56 gears, 35 spline axels, Chromo 3,5" drive shaft, 1350 U-joints.. Is the front pump drilled -No idea??? /Tom
[Re: TomsCharger70]
#2330736
07/03/17 03:58 PM
07/03/17 03:58 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends on power and engine RPM level, how quick it can 60', quality of track prep and tires, quality of components the trans is built with, amount of maintenance you expect to need to perform.
Your combination may be familiar with others here but I don't know what it is. Sorry if I'm the only one here who doesn't know.
[Re: TomsCharger70]
#2330766
07/03/17 04:44 PM
07/03/17 04:44 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
It's really hard on the tranny to use a trans brake below 3000 rpm. Best place to start is about 400 rpm below stall speed.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: TomsCharger70]
#2331805
07/05/17 10:39 AM
07/05/17 10:39 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I'd call Ultimate and see what they say about using your converter w/ a brake. If they say no problem, I'd do it.
