Question about Trans Brake #2330310
07/02/17 07:12 PM
07/02/17 07:12 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
Here is my question...
-Would a 727 survive leaving on a trans brake at about 2000-3000rpm when the car weighs 3902Lbs. My trans is a Cope built 727 with all options except a trans brake valvebody...
and..
-What Trans brake valve body would you recommend???
Thanks!
/Tom
Re: Question about Trans Brake [Re: TomsCharger70] #2330349
07/02/17 08:50 PM
07/02/17 08:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've always ran Griners, but currently have a Pro Trans clean N piece. Cope makes brakes now too. Is your torque converter built for T-brake usage?
what rear end, and driveline?
Re: Question about Trans Brake [Re: TomsCharger70] #2330353
07/02/17 08:56 PM
07/02/17 08:56 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Is the front pump drilled
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Question about Trans Brake [Re: TomsCharger70] #2330371
07/02/17 09:33 PM
07/02/17 09:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and what axles? I'd want 35 spline for sure.
Re: Question about Trans Brake [Re: J_BODY] #2330657
07/03/17 01:15 PM
07/03/17 01:15 PM
Stockholm, Sweden
Stockholm, Sweden
Originally Posted By J_BODY
I've always ran Griners, but currently have a Pro Trans clean N piece. Cope makes brakes now too. Is your torque converter built for T-brake usage? what rear end, and driveline?
-The converter is a brand new one from Ultimate, and no, I did not spec it out for transbrake use... Stall is +5000rpm.
-Rear axel is a Dana 60 (Dr. Diff/Strange). Detroit Locker, 4.56 gears, 35 spline axels, Chromo 3,5" drive shaft, 1350 U-joints..
-No idea???
/Tom
Re: Question about Trans Brake [Re: TomsCharger70] #2330726
07/03/17 03:35 PM
07/03/17 03:35 PM
Call or contact the converter company and ask them if that converter will be okay in front of a trans. brake twocents scope
Some of the better drag racing converters made years ago can't be used with a trans. brake now whiney shruggy
Re: Question about Trans Brake [Re: TomsCharger70] #2330736
07/03/17 03:58 PM
07/03/17 03:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends on power and engine RPM level, how quick it can 60', quality of track prep and tires, quality of components the trans is built with, amount of maintenance you expect to need to perform.
Your combination may be familiar with others here but I don't know what it is. Sorry if I'm the only one here who doesn't know.
Re: Question about Trans Brake [Re: TomsCharger70] #2330766
07/03/17 04:44 PM
07/03/17 04:44 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
It's really hard on the tranny to use a trans brake below 3000 rpm. Best place to start is about 400 rpm below stall speed.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Question about Trans Brake [Re: TomsCharger70] #2330772
07/03/17 05:05 PM
07/03/17 05:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Move the vent to the rear and plug the current
trans vent
wave
Re: Question about Trans Brake [Re: TomsCharger70] #2330803
07/03/17 06:13 PM
07/03/17 06:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Converter should have a steel stator. I had an aluminum one discintegrate, wiped out the converter.
Re: Question about Trans Brake [Re: TomsCharger70] #2330953
07/03/17 07:44 PM
07/03/17 07:44 PM
Stockholm, Sweden
Stockholm, Sweden
-Hmm, reading the responses it seems that a trans brake in my case is more a headache.... Ill just continue and foot brake this combo....
-Thank you for al the posts!!!
CMcAllister***
The combo is nothing that exotic. A stroker 493cid bottom end. Indy "Little" EZ 295 heads, roller cam, 11.0 comp., high rise intake, Dominator carb. 770Hp@6900Rpm/680Lbs/ft@5300Rpm... Still having some issues with getting the car off the line... Also I guess with a transbrake it would become even harder.... My "home" track does not have the track prep it used to...
Any way.. -Thanks again!
/Tom
Re: Question about Trans Brake [Re: TomsCharger70] #2331805
07/05/17 10:39 AM
07/05/17 10:39 AM
an8sec70cuda Offline
I'd call Ultimate and see what they say about using your converter w/ a brake. If they say no problem, I'd do it.
CHIP
'06 GMC 2500HD LBZ Duramax
