Rear main bearing oil seal kit question.... #2320514
06/13/17 12:52 PM
06/13/17 12:52 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
This piece is in the kit (red arrow). Anyone know what it is for? Thanks!
1970 Dodge Challenger T/A
Re: Rear main bearing oil seal kit question.... [Re: jeff968] #2320525
06/13/17 01:19 PM
06/13/17 01:19 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got one of those peices in a kit some time ago,all i can tell you is if you throw it at the garbage can it will hit the edge never to be seen again.
Re: Rear main bearing oil seal kit question.... [Re: jeff968] #2320551
06/13/17 02:18 PM
06/13/17 02:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
Those two pieces are stock on all LA SB Mopars I've worked on, they go in the cap to seal the main cap mating surface to the block scope up
Don't throw them away tsk
Re: Rear main bearing oil seal kit question.... [Re: Cab_Burge] #2320570
06/13/17 02:50 PM
06/13/17 02:50 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i thought that was for aBB,not to familiar w/SB
Re: Rear main bearing oil seal kit question.... [Re: Cab_Burge] #2322143
06/16/17 02:01 PM
06/16/17 02:01 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No that is not what they are for......
The Mopar B and RB share the same rear main seal as the Slant-6 and the part in question is for the Slant-6 application retainer seal.
Curious as to what brand rear seal that is and where you got it?
Re: Rear main bearing oil seal kit question.... [Re: roadhazard] #2322184
06/16/17 03:49 PM
06/16/17 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Slant Six side seals.
Re: Rear main bearing oil seal kit question.... [Re: jeff968] #2322266
06/16/17 05:57 PM
06/16/17 05:57 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There is a new Fel Pro seal that I got that has a more rigid side seal BS 40240.I have yet to install mine but I think it will be better.
Re: Rear main bearing oil seal kit question.... [Re: jeff968] #2322393
06/16/17 11:32 PM
06/16/17 11:32 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
They were in a Fel Pro rear seal kit that I bought about 3 months ago for my Hemi, and yes they went in the garbage can.
Re: Rear main bearing oil seal kit question.... [Re: rowin4] #2322553
06/17/17 11:08 AM
06/17/17 11:08 AM
moparx Offline
moparx  Offline
in the garbage can ? you mean you don't save "everything" like i do ? ya just "never" know....... i grew up around people that went through the depression, and unfortunately, that mentality was ingrained in me. nothing ever gets tossed, and i whine and crab because i got too much junk. go figure....
beer
Re: Rear main bearing oil seal kit question.... [Re: jeff968] #2322582
06/17/17 12:18 PM
06/17/17 12:18 PM
rowin4 Offline
rowin4  Offline
I'm still going through the Depression and I still throw them away.
