Rear main bearing oil seal kit question....
#2320514
06/13/17 12:52 PM
06/13/17 12:52 PM
Posts: 4,051 Connecticut
jeff968
Connecticut
This piece is in the kit (red arrow). Anyone know what it is for? Thanks!
1970 Dodge Challenger T/A
Re: Rear main bearing oil seal kit question....
[Re: jeff968]
#2320551
06/13/17 02:18 PM
06/13/17 02:18 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
Those two pieces are stock on all LA SB Mopars I've worked on, they go in the cap to seal the main cap mating surface to the block Don't throw them away
[Re: Cab_Burge]
#2322143
06/16/17 02:01 PM
06/16/17 02:01 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Those two pieces are stock on all LA SB Mopars I've worked on, they go in the cap to seal the main cap mating surface to the block Don't throw them away No that is not what they are for...... The Mopar B and RB share the same rear main seal as the Slant-6 and the part in question is for the Slant-6 application retainer seal. Curious as to what brand rear seal that is and where you got it?
[Re: jeff968]
#2322266
06/16/17 05:57 PM
06/16/17 05:57 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
There is a new Fel Pro seal that I got that has a more rigid side seal BS 40240.I have yet to install mine but I think it will be better.
[Re: jeff968]
#2322393
06/16/17 11:32 PM
06/16/17 11:32 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
They were in a Fel Pro rear seal kit that I bought about 3 months ago for my Hemi, and yes they went in the garbage can.
[Re: jeff968]
#2322582
06/17/17 12:18 PM
06/17/17 12:18 PM
rowin4
I'm still going through the Depression and I still throw them away.
