Page 1 of 4 1 2 3 4
1970 440 HP Vs HP2 ?? #23207
01/25/06 08:41 PM
01/25/06 08:41 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Is there a difference between the HP and the HP2??
Re: 1970 440 HP Vs HP2 ?? [Re: mc4406] #23208
01/25/06 08:44 PM
01/25/06 08:44 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
shift built on
Re: 1970 440 HP Vs HP2 ?? [Re: 05dakota] #23209
01/25/06 08:45 PM
01/25/06 08:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 1970 440 HP Vs HP2 ?? [Re: 05dakota] #23210
01/25/06 08:46 PM
01/25/06 08:46 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Thats what i've heard before, But someone told me the other day, They thought HP2 went into 6 pack cars and HP where 440-4 cars
Re: 1970 440 HP Vs HP2 ?? [Re: mc4406] #23211
01/25/06 08:49 PM
01/25/06 08:49 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
wrong
Re: 1970 440 HP Vs HP2 ?? [Re: 05dakota] #23212
01/25/06 08:51 PM
01/25/06 08:51 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Thanks For the info
Re: 1970 440 HP Vs HP2 ?? [Re: mc4406] #23213
01/25/06 09:34 PM
01/25/06 09:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
... WRONG ...
Re: 1970 440 HP Vs HP2 ?? [Re: mc4406] #23214
01/25/06 09:39 PM
01/25/06 09:39 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Yes ,big difference; those HP2 blocks have a high nickel content and four bolt mains!!!.
Oh never mind thats ford and gm stuff.
Re: 1970 440 HP Vs HP2 ?? [Re: formula_s] #23215
01/25/06 10:00 PM
01/25/06 10:00 PM
Right Coast
Fabman Offline
Fabman  Offline
Right Coast
did they ever build a 4 bolt main block 440?
Re: 1970 440 HP Vs HP2 ?? [Re: Fabman] #23216
01/25/06 10:03 PM
01/25/06 10:03 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah it's a small bore version called a Hemi.
Re: 1970 440 HP Vs HP2 ?? [Re: Fabman] #23217
01/25/06 10:36 PM
01/25/06 10:36 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
Aren't the new 440 engines in the Mopar Performance catalog cross bolted mains? They look it from the pics.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: 1970 440 HP Vs HP2 ?? [Re: bschargerse] #23218
01/26/06 12:33 AM
01/26/06 12:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
why yes they are , i have one
Re: 1970 440 HP Vs HP2 ?? [Re: mc4406] #23219
01/26/06 10:34 AM
01/26/06 10:34 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
The 500 wedges are 4 bolt mains
Re: 1970 440 HP Vs HP2 ?? [Re: 05dakota] #23220
01/26/06 12:48 PM
01/26/06 12:48 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
So the only difference between the HP and HP2 is the shift it was built on.
How do you tell if it was a 440-4 or a 440-6pac engine. Was there a stamp or number on the block.
I know the v in the Vin is for six pack engine.
Also what does a B stamped on the pad mean.
Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23221
01/26/06 12:55 PM
01/26/06 12:55 PM
Wanna know what my 1970 dodge 440 SIXPACK block says on the "dist pad area".?
Re: 1970 440 HP Vs HP2 ?? #23222
01/26/06 01:00 PM
01/26/06 01:00 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
hp2 is block built on the day shift, all hp2 blocks are not six pack blocks.
Re: 1970 440 HP Vs HP2 ?? [Re: 05dakota] #23223
01/26/06 01:07 PM
01/26/06 01:07 PM
I am not so sure about that dak man mine says HP then space then 2 then next line says F440 then the diamond which I believe is the pressure test stamping. Every article I have ever read by the "experts" states something new or supercedes something else.
Re: 1970 440 HP Vs HP2 ?? #23224
01/26/06 01:17 PM
01/26/06 01:17 PM
Do you dudes remember the old MuscleCar Review Magazine? There was an excellent article by roger gibson on correctly detailing the 440sixpack/6bbl engine I think it was the fall 97 issue. It states all 440-4 barrel was h.p. only all sixpacks were H.P.2 only however this has been debuked countless times since then!!
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23225
01/26/06 01:34 PM
01/26/06 01:34 PM
Ohio
john55 Offline
john55  Offline
Ohio
IIRC the 440 6 bbl had a different piston than the 440 magnum, pretty hard to tell if a block was a 6bbl if you couldn't see the pistons, or have the partial vin on the r/s of block and you knew for sure the vin was for a 6 bbl car......just my opinion,you don't have to agree or disagree......
The Plymouth Win You Over Beat Goes On
Re: 1970 440 HP Vs HP2 ?? #23226
01/26/06 01:38 PM
01/26/06 01:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats why many think it because, roger gibson said so .
its has been proven FALSE ...
the only way to tell an original 6pk shortblock is to find an unmolested block , it MUST have these 2 items , first is pistons with 4 valve reliefs , second is a cam that takes a 3 bolt timing gear , it MUST HAVE BOTH
Page 1 of 4 1 2 3 4
