Can anyone identify this 360 block? (with pics)
#231604
02/21/09 06:14 PM
02/21/09 06:14 PM
Posts: 171 Columbus, OH
redruM
Columbus, OH
Re: Can anyone identify this 360 block? (with pics)
[Re: HotRodDave]
#231608
02/21/09 07:36 PM
02/21/09 07:36 PM
redruM
Columbus, OH
I almost bought, guy said it was a race block. I asked how come it doesn't have an r on the front, he said its not an r series just a high nickel, tall deck block. Thanks anyway EDIT- Didn't see the other replies. I have the block in my possession for the moment, are there any dead give aways? The main caps do look like factory part imo.
[Re: Hot 340]
#231612
02/21/09 08:25 PM
02/21/09 08:25 PM
redruM
Columbus, OH
Look down into the soft plug holes on the sides for giggles... are the bores siamesed?
Nope, gap between the bores.
[Re: Hot 340]
#231613
02/21/09 08:26 PM
02/21/09 08:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
the very first pic shows space between the cylinders, very dark but you can see it.
Caps are definately not stock caps. The whole thing looks freshly machined and as long as it is not bored more than about .030 over I would say it is worth at least $500-700 with the cap upgrade, mabey a little more to a guy looking for something machined and ready to build because of the money he would save.
[Re: HotRodDave]
#231614
02/21/09 08:28 PM
02/21/09 08:28 PM
Posts: 3,395 Pa
Hot 340
Pa
Yep. I see it now..
[Re: MR_P_BODY]
#231615
02/21/09 08:28 PM
02/21/09 08:28 PM
redruM
Columbus, OH
That block isnt drilled for a oil pump
lol, I noticed that, oil pumps are overrated.
[Re: redruM]
#231616
02/21/09 08:33 PM
02/21/09 08:33 PM
HotRodDave
Kalispell Mt.
Cap is not drilled but that don't mean the block isn't.
[Re: HotRodDave]
#231617
02/21/09 08:52 PM
02/21/09 08:52 PM
redruM
Columbus, OH
Well I pulled out a 74 360 block for comparison. The blocks are def different, the main webbing is much thicker, the block has normal oiling provisions why the cap doesn't i dunno. The pan rails are completely filled as someone stated earlier, where as the 74 block is recessed.
What kind of power in your opinion can this thing handle? Its supposed to be taller deck than a standard block, how would I measure that?
Also it has been freshly machined, bore is 4.04
[Re: redruM]
#231618
02/21/09 09:05 PM
02/21/09 09:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Other than the bolt holes in the cap it looks like it could be added.... I have no idea if the block itself is drilled for the pump... but a external pump could be used easily... over all it looks beefy but that would depend on a sonic check
[Re: redruM]
#231619
02/21/09 09:14 PM
02/21/09 09:14 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Deck height is measured from the center of the mains to the deck of the block.
