Can anyone identify this 360 block? (with pics) #231604
02/21/09 06:14 PM
02/21/09 06:14 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231605
02/21/09 07:18 PM
02/21/09 07:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Just an average 1979 360 with what looks like billet main caps added. Should be a nice foundation for a strong street motor
I would add studs to take advantage of the good caps.
Re: Can anyone identify this 360 block? (with pics) [Re: HotRodDave] #231606
02/21/09 07:32 PM
02/21/09 07:32 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I think that might be a "BACK DOOR" mopar 360 block for the SS cars back in the day. I have seen one other.
Re: Can anyone identify this 360 block? (with pics) [Re: HotRodDave] #231607
02/21/09 07:33 PM
02/21/09 07:33 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
The pan rails are filled in more than my 70s 360 blocks.Are the later blocks all filled in there?
Re: Can anyone identify this 360 block? (with pics) [Re: HotRodDave] #231608
02/21/09 07:36 PM
02/21/09 07:36 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
I almost bought, guy said it was a race block. I asked how come it doesn't have an r on the front, he said its not an r series just a high nickel, tall deck block. Thanks anyway
EDIT- Didn't see the other replies. I have the block in my possession for the moment, are there any dead give aways? The main caps do look like factory part imo.
Re: Can anyone identify this 360 block? (with pics) [Re: W5DART66] #231609
02/21/09 07:43 PM
02/21/09 07:43 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It's not a standard passenger car block.
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231610
02/21/09 08:05 PM
02/21/09 08:05 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Look down into the soft plug holes on the sides for giggles... are the bores siamesed?
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231611
02/21/09 08:21 PM
02/21/09 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That block isnt drilled for a oil pump
Re: Can anyone identify this 360 block? (with pics) [Re: Hot 340] #231612
02/21/09 08:25 PM
02/21/09 08:25 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Nope, gap between the bores.
Re: Can anyone identify this 360 block? (with pics) [Re: Hot 340] #231613
02/21/09 08:26 PM
02/21/09 08:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the very first pic shows space between the cylinders, very dark but you can see it.
Caps are definately not stock caps. The whole thing looks freshly machined and as long as it is not bored more than about .030 over I would say it is worth at least $500-700 with the cap upgrade, mabey a little more to a guy looking for something machined and ready to build because of the money he would save.
Re: Can anyone identify this 360 block? (with pics) [Re: HotRodDave] #231614
02/21/09 08:28 PM
02/21/09 08:28 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Yep. I see it now..
Re: Can anyone identify this 360 block? (with pics) [Re: MR_P_BODY] #231615
02/21/09 08:28 PM
02/21/09 08:28 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
lol, I noticed that, oil pumps are overrated.
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231616
02/21/09 08:33 PM
02/21/09 08:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Cap is not drilled but that don't mean the block isn't.
Re: Can anyone identify this 360 block? (with pics) [Re: HotRodDave] #231617
02/21/09 08:52 PM
02/21/09 08:52 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Well I pulled out a 74 360 block for comparison. The blocks are def different, the main webbing is much thicker, the block has normal oiling provisions why the cap doesn't i dunno. The pan rails are completely filled as someone stated earlier, where as the 74 block is recessed.
What kind of power in your opinion can this thing handle? Its supposed to be taller deck than a standard block, how would I measure that?
Also it has been freshly machined, bore is 4.04
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231618
02/21/09 09:05 PM
02/21/09 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Other than the bolt holes in the cap it looks like
it could be added.... I have no idea if the block
itself is drilled for the pump... but a external
pump could be used easily... over all it looks beefy
but that would depend on a sonic check
Re: Can anyone identify this 360 block? (with pics) [Re: redruM] #231619
02/21/09 09:14 PM
02/21/09 09:14 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Deck height is measured from the center of the mains to the deck of the block.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Can anyone identify this 360 block? (with pics) [Re: DemonDust] #231620
02/21/09 10:01 PM
02/21/09 10:01 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
^^ Thanks
Its measures slighty under 10 inches, from deck to main center.
