Re: Help getting steering wheel straight on my Challenger
[Re: SportF]
#2315398
06/03/17 12:31 AM
06/03/17 12:31 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The new "box" is the key here. Dr Dave has the right answer and probably the only answer, and the easiest answer, all at the same time.
Its just that the rest of the mopar world will call you a hack and would rather live with the wheel off than fix it Dave's way. As I said before, doing this way is worse than owning two cone sure grips at the same time.
Dr Daves answer. File the fat looking key out of the steering wheel and put it on straight. Then, don't tell anybody.....just go quiet......... That's akin to putting a band air on your head and leaving the crowbar in that causing the bleeding. Something is wrong, fix it. and the master spline on the steering wheel is not the problem. Listening to hacks can be though.
[Re: patosmith]
#2315470
06/03/17 04:19 AM
06/03/17 04:19 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Lay odds that turn signal cancelling does not function as it should if you are off more than just a little. You are right! I can handle the spokes being off until I find the problem but the turn signal cancelling is driving me nuts. TS cancel will never function correctly until steering wheel is positioned correctly when front wheels are at straight ahead. However you should be able to Bubba it by reposition of cancel cam inside of crush can. Not advisable but can be done as I recall,,,,,far better to correct initial problem as steering box is not operating at top center when driving straight ahead. This is not good
[Re: Supercuda]
#2315533
06/03/17 12:20 PM
06/03/17 12:20 PM
RapidRobert
What Supercuda said, we gotta ID the problem first. Keep after it.
[Re: patosmith]
#2315638
06/03/17 04:59 PM
06/03/17 04:59 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Jeez....
It is impossible for a rebuilder to reassemble the box 90 deg "out". Twisted splines, I have seen, but you'd think they would have caught that.
The problem is was there is no known "before" condition. Turn the wheel as you described, exactly 1/2 way between the stops, regardless of wheel position. Then snap (and post) a pix from underneath looking straight up at the pitman. We'll know if the problem is with the box / pitman / column / wheel or bent steering linkage.
Rick
[Re: patosmith]
#2315714
06/03/17 08:50 PM
06/03/17 08:50 PM
Posts: 5,883 ohio
ruderunner
ohio
This.
It's not rocket science. If your local front end shop can't spot this in 5 minutes on the rack, find a different shop. And don't let them do your laundry either.
Angry white pureblood male
