Re: Help getting steering wheel straight on my Challenger [Re: Dave Hall] #2315372
06/02/17 11:11 PM
06/02/17 11:11 PM
IN
ahy Offline
ahy  Offline
IN
Did you by chance disassemble the pot connector(column to box)? That is the only thing in the "E" system that is not clocked. If re-assembled 180 degrees out, it will cause the problem you have. Don't ask me how I know...
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2315387
06/03/17 12:18 AM
06/03/17 12:18 AM
Minn
SportF Offline
SportF  Offline
Minn
The new "box" is the key here. Dr Dave has the right answer and probably the only answer, and the easiest answer, all at the same time.
Its just that the rest of the mopar world will call you a hack and would rather live with the wheel off than fix it Dave's way. As I said before, doing this way is worse than owning two cone sure grips at the same time.
Dr Daves answer. File the fat looking key out of the steering wheel and put it on straight. Then, don't tell anybody.....just go quiet.........
Re: Help getting steering wheel straight on my Challenger [Re: SportF] #2315398
06/03/17 12:31 AM
06/03/17 12:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's akin to putting a band air on your head and leaving the crowbar in that causing the bleeding.
Something is wrong, fix it. and the master spline on the steering wheel is not the problem. Listening to hacks can be though.
Don't be the exception.
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2315470
06/03/17 04:19 AM
06/03/17 04:19 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Originally Posted By patosmith
Originally Posted By Sxrxrnr
Lay odds that turn signal cancelling does not function as it should if you are off more than just a little.
You are right! I can handle the spokes being off until I find the problem but the turn signal cancelling is driving me nuts.
TS cancel will never function correctly until steering wheel is positioned correctly when front wheels are at straight ahead.
However you should be able to Bubba it by reposition of cancel cam inside of crush can. Not advisable but can be done as I recall,,,,,far better to correct initial problem as steering box is not operating at top center when driving straight ahead. This is not good
Re: Help getting steering wheel straight on my Challenger [Re: Supercuda] #2315533
06/03/17 12:20 PM
06/03/17 12:20 PM
Something is wrong,
What Supercuda said, we gotta ID the problem first. Keep after it.
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2315595
06/03/17 02:39 PM
06/03/17 02:39 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I agree with getting to the bottom of it. My car is a '73 Dart Sport. A LOOONG way from a restored E-body. Did I care about re-clocking the wheel? No. Does it drive great? Yes.
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2315638
06/03/17 04:59 PM
06/03/17 04:59 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Jeez....
It is impossible for a rebuilder to reassemble the box 90 deg "out". Twisted splines, I have seen, but you'd think they would have caught that.
The problem is was there is no known "before" condition. Turn the wheel as you described, exactly 1/2 way between the stops, regardless of wheel position. Then snap (and post) a pix from underneath looking straight up at the pitman. We'll know if the problem is with the box / pitman / column / wheel or bent steering linkage.
Rick
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2315714
06/03/17 08:50 PM
06/03/17 08:50 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
This.
It's not rocket science. If your local front end shop can't spot this in 5 minutes on the rack, find a different shop. And don't let them do your laundry either.
Angry white pureblood male
Re: Help getting steering wheel straight on my Challenger [Re: patosmith] #2392240
10/24/17 11:05 AM
10/24/17 11:05 AM
Germany
JS23U Offline
JS23U  Offline
Germany
I know that exact problem. Have "new" boxes in both cars. Installed one in the Challenger 10 years ago, and just installed a Firm Feel box in the Bee. Both cars have the problem that the steering wheel isn't straight after just exchanging the steering box. On one car the steering wheel points to the left, on the other to the right, albeit not very much. One or two teeth re-clocking should do it, but I haven't done it yet.
