Page 1 of 3 1 2 3
in tank fuel pump Fitech Efi #2314111
05/31/17 11:43 AM
05/31/17 11:43 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Is there anyone who has installed an in tank fuel pump on his Plymouth B-body?
I have a Fitech EFI, 30002, with the Fuel command center, however I don't want to use the FCC. I want a clean engine bay. Besides that the in tank fuel pump reduces chance of vapor lock.
I found out that Spectra sells a Classic Fuel Injection Tank with pump, partnumber CR9CFI with the following specifications:
55-85 psi
200 LPH/58.6 GPH
The EFI throttlebody needs 58 psi and the FCC delivers 340 LPH so the Spectra tank isn't an option.
Which brand/partnumber did you use?
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314115
05/31/17 11:52 AM
05/31/17 11:52 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
tanksinc is what my car is getting
Pretty sure the spectra will work fine. The throttlebody has a return line anyway.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314257
05/31/17 05:57 PM
05/31/17 05:57 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Any other options then the tankinc?
Don't mind to fabricate an in tank pump in the old tank.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314269
05/31/17 06:52 PM
05/31/17 06:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Buy a Tanks Inc pump and their weld-in tank adapter and you're off to the races.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314282
05/31/17 07:43 PM
05/31/17 07:43 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
So is the FiTech Fuel Command Center is obsolete if you have an in tank pump?
Facts are stubborn things.
Re: in tank fuel pump Fitech Efi [Re: larrymopar360] #2314319
05/31/17 09:37 PM
05/31/17 09:37 PM
SW CO
HemiSportFury Offline
SW CO
I modified my 64 b-body tank to install an Aermotive Phantom 340 pump. Works fine and is quite.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314472
06/01/17 09:02 AM
06/01/17 09:02 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I bought a TanksInc tank and a Aeromotive 340 pump with the JakeFab puck. No concerns.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314496
06/01/17 10:58 AM
06/01/17 10:58 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If the in tank pump is sufficient to feed the injectors then yes, the command center is not needed.
Re: in tank fuel pump Fitech Efi [Re: Stanton] #2314501
06/01/17 11:16 AM
06/01/17 11:16 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314894
06/01/17 11:43 PM
06/01/17 11:43 PM
tucson az
frank Offline
frank  Offline
tucson az
I went with a TanksInc tank for my 68 Charger and I'm not very happy with it. I used their in-tank pump setup and I will not go this route again. I had clearance problems and leak problems. In my other car (69 GTX) I used a stock tank (Spectra IIRC) and an Aeromotive Stealth 340 pump. In this case a hole was cut in the top of the tank, pump installed and the tank sealed back up. Two AN fittings are welded to the top of the fuel pump cover. Much cleaner and less prone to leak. The TankInc uses NPT fittings.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2314904
06/02/17 12:00 AM
06/02/17 12:00 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
On my Ebody, I have had the Tanks and the Spectra EFI tanks.
Spectra all the way.
Re: in tank fuel pump Fitech Efi [Re: frank] #2314919
06/02/17 12:22 AM
06/02/17 12:22 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have no issues with NPT fittings, but the TanksInc fuel pump solution is quite mediocre. In my opinion. I bought a JakeFab puck, which also uses NPT fittings, but worked out well for me. No leaks out of the gate.
2020 RAM 1500
Re: in tank fuel pump Fitech Efi [Re: denfireguy] #2314998
06/02/17 07:57 AM
06/02/17 07:57 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Which EFI did you use?
Re: in tank fuel pump Fitech Efi [Re: GoodysGotaCuda] #2314999
06/02/17 08:01 AM
06/02/17 08:01 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
This setup is for you Challenger? Looks nice. Which pump did you use?
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2315005
06/02/17 09:16 AM
06/02/17 09:16 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes it is in my ebody. Aeromotive Stealth 340lph
2020 RAM 1500
Re: in tank fuel pump Fitech Efi [Re: GoodysGotaCuda] #2315361
06/02/17 10:54 PM
06/02/17 10:54 PM
tucson az
frank Offline
frank  Offline
tucson az
I believe this is the way to go.
Re: in tank fuel pump Fitech Efi [Re: frank] #2315611
06/03/17 03:34 PM
06/03/17 03:34 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
What's that? You fabricate your own?
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2315745
06/03/17 11:12 PM
06/03/17 11:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I believe that's an efi tank adapter from Tanks Inc. (or similar)
Re: in tank fuel pump Fitech Efi [Re: denfireguy] #2315944
06/04/17 01:58 PM
06/04/17 01:58 PM
BDW Offline
BDW  Offline
I'm finishing up my install with the Spectra EFI tank based on your input.
Will report back if I can ever get this thing done, seems like every time I take a step forward, I find 2 other things that need fixed.
Re: in tank fuel pump Fitech Efi [Re: larrymopar360] #2316227
06/04/17 09:48 PM
06/04/17 09:48 PM
tucson az
frank Offline
frank  Offline
tucson az
Thats a stock spec tank fitted with a Stealth 340 pump. I have a carb setup with return. I wish my fab skills were that good. This is a product of Ricks Tanks
Page 1 of 3 1 2 3
