4 link suspension #2311348
05/26/17 02:18 AM
05/26/17 02:18 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 4 link suspension [Re: AZ_A12_BEE] #2311392
05/26/17 08:18 AM
05/26/17 08:18 AM
AZ
Mike P Offline
Mike P  Offline
AZ
I suspect you've probably already come across this but I'll throw it out in case you haven't.
http://www.ridetech.com/info/air4link-tech/
For bushings I usually prefer the rubber ones.....but with the power and tires you are going to be running I'd probably seriously consider urethane. Just make sure you get ones that can greased.
On spring rates it's probably going to be best to talk to the manufacture or you could go air bags.
One of the things to consider for the springs will be fuel tank location and size. A 20 gallon fuel tank hung under the bed behind the rear axle will probably require a bit stiffer spring than a 15 gallon tank mounted in the front of the bed.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 4 link suspension [Re: AZ_A12_BEE] #2312169
05/27/17 11:27 PM
05/27/17 11:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available. wave
Fastest 300
Re: 4 link suspension [Re: Crizila] #2312186
05/28/17 12:30 AM
05/28/17 12:30 AM
Dreaming of the 808
Dreaming of the 808
Crizila, what brand did you use?
Re: 4 link suspension [Re: AZ_A12_BEE] #2313250
05/29/17 09:54 PM
05/29/17 09:54 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually came as part of the frame / suspension package with the 33 body. Left me a nice big opening behind the axle housing ( inside the frame rails ) for a fuel tank. Lots to choose from with Carrera coil-overs.
Fastest 300
Re: 4 link suspension [Re: Crizila] #2396183
10/31/17 05:40 PM
10/31/17 05:40 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually, I believe it's a Speedway kit.
Fastest 300
Re: 4 link suspension [Re: Crizila] #2399602
11/06/17 09:14 PM
11/06/17 09:14 PM
dogdays Offline
dogdays  Offline
I hope you can adjust the Instant Center on those rods. The same geometry was used on the GM A-bodies like Chevelles. Those cars had the instant center too far towards the front. The rears would hop under hard acceleration. The cure was to relocate the upper bar attachment to the axle, higher. This shortened up the instant center and voila! no more hops.
R.
Re: 4 link suspension [Re: dogdays] #2399865
11/07/17 10:57 AM
11/07/17 10:57 AM
moparx Offline
moparx  Offline
the old lakewood "no hop" bars. i think there may be someone other than lakewood producing those today, but i haven't seen any lakewood brand of those for years.
beer
Re: 4 link suspension [Re: moparx] #2400814
11/09/17 01:16 AM
11/09/17 01:16 AM
Canada
CrAzYMoPaRGuY Offline
Canada
beer
We used those. They took the word "suspension" right out of the rearend......
CrAzYMoPaRGuY
Re: 4 link suspension [Re: dogdays] #2400912
11/09/17 11:31 AM
11/09/17 11:31 AM
Az
Crizila Offline
Crizila  Offline
Az
R.
Yep, I hear you on that. To be honest, I have yet to stomp on it from a dead stop, but it might hop a bunch. As you can see from the pic, room constraints are an issue. Think I would have to go to a conventional 4 link and pan hard rod to fix it.
Fastest 300
Re: 4 link suspension [Re: AZ_A12_BEE] #2401065
11/09/17 05:28 PM
11/09/17 05:28 PM
usa
csmopar Offline
csmopar  Offline
usa
I personally went with the Gerst made parallel watts link kit. pretty neat kit all told.
Re: 4 link suspension [Re: csmopar] #2401597
11/10/17 09:49 PM
11/10/17 09:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Could you post a pic?
Fastest 300
Re: 4 link suspension [Re: Crizila] #2403505
11/14/17 02:18 PM
11/14/17 02:18 PM
usa
csmopar Offline
csmopar  Offline
usa
pm me your email and ill send you some. I've not figured out how to post pictures here now that photobucket changed their 3rd party links.
Re: 4 link suspension [Re: dogdays] #2407614
11/22/17 11:24 PM
11/22/17 11:24 PM
Az
Crizila Offline
Crizila  Offline
Az
R.
Remember, this is a street rod, not a drag car. There is a difference in application between a 4 bar and a 4 link rear suspension. Mine is a triangulated 4 bar - best suited for street rods / "g" machines. 4 links are best suited for drag /race cars ( much more instant center adjust ability for track conditions).
Fastest 300
Re: 4 link suspension [Re: Crizila] #2408233
11/24/17 01:57 PM
11/24/17 01:57 PM
Dreaming of the 808
Dreaming of the 808
R.
Mine will be street so you suggest a 4 bar over a 4 link?
Re: 4 link suspension [Re: AZ_A12_BEE] #2408357
11/24/17 06:34 PM
11/24/17 06:34 PM
Az
Crizila Offline
Crizila  Offline
Az
R.
Yes, especially if you have any kind of room constraint issues, which street rods often have.
Fastest 300
