4 link suspension
#2311348
05/26/17 02:18 AM
05/26/17 02:18 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: 4 link suspension
[Re: AZ_A12_BEE]
#2311392
05/26/17 08:18 AM
05/26/17 08:18 AM
Posts: 1,511 AZ
Mike P
AZ
I suspect you've probably already come across this but I'll throw it out in case you haven't. http://www.ridetech.com/info/air4link-tech/ For bushings I usually prefer the rubber ones.....but with the power and tires you are going to be running I'd probably seriously consider urethane. Just make sure you get ones that can greased. On spring rates it's probably going to be best to talk to the manufacture or you could go air bags. One of the things to consider for the springs will be fuel tank location and size. A 20 gallon fuel tank hung under the bed behind the rear axle will probably require a bit stiffer spring than a 15 gallon tank mounted in the front of the bed.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: AZ_A12_BEE]
#2312169
05/27/17 11:27 PM
05/27/17 11:27 PM
Posts: 7,506 Az
Crizila
Az
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use? Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available.
Fastest 300
[Re: Crizila]
#2312186
05/28/17 12:30 AM
05/28/17 12:30 AM
AZ_A12_BEE
Dreaming of the 808
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use? Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available. Crizila, what brand did you use?
37 Plymouth PU
[Re: AZ_A12_BEE]
#2313250
05/29/17 09:54 PM
05/29/17 09:54 PM
Posts: 7,506 Az
Crizila
Az
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use? Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available. Crizila, what brand did you use? Actually came as part of the frame / suspension package with the 33 body. Left me a nice big opening behind the axle housing ( inside the frame rails ) for a fuel tank. Lots to choose from with Carrera coil-overs.
Fastest 300
[Re: Crizila]
#2396183
10/31/17 05:40 PM
10/31/17 05:40 PM
Posts: 7,506 Az
Crizila
Az
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use? Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available. Crizila, what brand did you use? Actually came as part of the frame / suspension package with the 33 body. Left me a nice big opening behind the axle housing ( inside the frame rails ) for a fuel tank. Lots to choose from with Carrera coil-overs. Actually, I believe it's a Speedway kit.
Fastest 300
[Re: moparx]
#2400814
11/09/17 01:16 AM
11/09/17 01:16 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
the old lakewood "no hop" bars. i think there may be someone other than lakewood producing those today, but i haven't seen any lakewood brand of those for years. We used those. They took the word "suspension" right out of the rearend......
CrAzYMoPaRGuY
[Re: dogdays]
#2400912
11/09/17 11:31 AM
11/09/17 11:31 AM
Posts: 7,506 Az
Crizila
Az
I hope you can adjust the Instant Center on those rods. The same geometry was used on the GM A-bodies like Chevelles. Those cars had the instant center too far towards the front. The rears would hop under hard acceleration. The cure was to relocate the upper bar attachment to the axle, higher. This shortened up the instant center and voila! no more hops.
R. Yep, I hear you on that. To be honest, I have yet to stomp on it from a dead stop, but it might hop a bunch. As you can see from the pic, room constraints are an issue. Think I would have to go to a conventional 4 link and pan hard rod to fix it.
Fastest 300
[Re: csmopar]
#2401597
11/10/17 09:49 PM
11/10/17 09:49 PM
Posts: 7,506 Az
Crizila
Az
I personally went with the Gerst made parallel watts link kit. pretty neat kit all told. Could you post a pic?
Fastest 300
[Re: dogdays]
#2407614
11/22/17 11:24 PM
11/22/17 11:24 PM
Posts: 7,506 Az
Crizila
Az
R. Remember, this is a street rod, not a drag car. There is a difference in application between a 4 bar and a 4 link rear suspension. Mine is a triangulated 4 bar - best suited for street rods / "g" machines. 4 links are best suited for drag /race cars ( much more instant center adjust ability for track conditions).
Fastest 300
[Re: Crizila]
#2408233
11/24/17 01:57 PM
11/24/17 01:57 PM
AZ_A12_BEE
Dreaming of the 808
R. Remember, this is a street rod, not a drag car. There is a difference in application between a 4 bar and a 4 link rear suspension. Mine is a triangulated 4 bar - best suited for street rods / "g" machines. 4 links are best suited for drag /race cars ( much more instant center adjust ability for track conditions). Mine will be street so you suggest a 4 bar over a 4 link?
37 Plymouth PU
[Re: AZ_A12_BEE]
#2408357
11/24/17 06:34 PM
11/24/17 06:34 PM
Posts: 7,506 Az
Crizila
Az
R. Remember, this is a street rod, not a drag car. There is a difference in application between a 4 bar and a 4 link rear suspension. Mine is a triangulated 4 bar - best suited for street rods / "g" machines. 4 links are best suited for drag /race cars ( much more instant center adjust ability for track conditions). Mine will be street so you suggest a 4 bar over a 4 link? Yes, especially if you have any kind of room constraint issues, which street rods often have.
Fastest 300
