#2311348 - 05/26/17 12:18 AM 4 link suspension
AZ_A12_BEE Offline
Loc: Dreaming of the 808
Shopping for a 4 link kit, which is better parallel with pan hard bar or triangulated ? Rubber or urathane bushings? How do you figure out which coil over to use?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
#2311392 - 05/26/17 06:18 AM Re: 4 link suspension [Re: AZ_A12_BEE]
Mike P Offline
Loc: AZ
I suspect you've probably already come across this but I'll throw it out in case you haven't.
http://www.ridetech.com/info/air4link-tech/
For bushings I usually prefer the rubber ones.....but with the power and tires you are going to be running I'd probably seriously consider urethane. Just make sure you get ones that can greased.
On spring rates it's probably going to be best to talk to the manufacture or you could go air bags.
One of the things to consider for the springs will be fuel tank location and size. A 20 gallon fuel tank hung under the bed behind the rear axle will probably require a bit stiffer spring than a 15 gallon tank mounted in the front of the bed.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10)
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56)
#2312169 - 05/27/17 09:27 PM Re: 4 link suspension [Re: AZ_A12_BEE]
Crizila Offline
Loc: Az
Good article Mike P. I went with a triangulated 4 link on my 33. Carrera coil overs. It does help with the room issue. Polly bushings for sure. A ton of adjustability is available. wave
Edited by Crizila (05/27/17 09:28 PM)
Fastest 300
#2312186 - 05/27/17 10:30 PM Re: 4 link suspension [Re: Crizila]
AZ_A12_BEE Offline
Crizila, what brand did you use?
#2313250 - 05/29/17 07:54 PM Re: 4 link suspension [Re: AZ_A12_BEE]
Crizila Offline
Loc: Az
Actually came as part of the frame / suspension package with the 33 body. Left me a nice big opening behind the axle housing ( inside the frame rails ) for a fuel tank. Lots to choose from with Carrera coil-overs.
Fastest 300
#2396183 - 10/31/17 03:40 PM Re: 4 link suspension [Re: Crizila]
Crizila Offline
Loc: Az
Actually, I believe it's a Speedway kit.
Fastest 300
#2399602 - 11/06/17 06:14 PM Re: 4 link suspension [Re: Crizila]
dogdays Offline
I hope you can adjust the Instant Center on those rods. The same geometry was used on the GM A-bodies like Chevelles. Those cars had the instant center too far towards the front. The rears would hop under hard acceleration. The cure was to relocate the upper bar attachment to the axle, higher. This shortened up the instant center and voila! no more hops.
R.
#2399865 - 11/07/17 07:57 AM Re: 4 link suspension [Re: dogdays]
moparx Offline
Dreaming of implants
Loc: north of coder
the old lakewood "no hop" bars. i think there may be someone other than lakewood producing those today, but i haven't seen any lakewood brand of those for years.
beer
#2400814 - 11/08/17 10:16 PM Re: 4 link suspension [Re: moparx]
CrAzYMoPaRGuY Online   content
Loc: Canada
beer
We used those. They took the word "suspension" right out of the rearend......
CrAzYMoPaRGuY
#2400912 - 11/09/17 08:31 AM Re: 4 link suspension [Re: dogdays]
Crizila Offline
Loc: Az
R.
Yep, I hear you on that. To be honest, I have yet to stomp on it from a dead stop, but it might hop a bunch. As you can see from the pic, room constraints are an issue. Think I would have to go to a conventional 4 link and pan hard rod to fix it.
Fastest 300
#2401065 - 11/09/17 02:28 PM Re: 4 link suspension [Re: AZ_A12_BEE]
csmopar Offline
Loc: usa
I personally went with the Gerst made parallel watts link kit. pretty neat kit all told.
#2401597 - 11/10/17 06:49 PM Re: 4 link suspension [Re: csmopar]
Crizila Offline
Loc: Az
Could you post a pic?
Fastest 300
#2403505 - 11/14/17 11:18 AM Re: 4 link suspension [Re: Crizila]
csmopar Offline
Loc: usa
pm me your email and ill send you some. I've not figured out how to post pictures here now that photobucket changed their 3rd party links.
#2407614 - 11/22/17 08:24 PM Re: 4 link suspension [Re: dogdays]
Crizila Offline
Loc: Az
R.
Remember, this is a street rod, not a drag car. There is a difference in application between a 4 bar and a 4 link rear suspension. Mine is a triangulated 4 bar - best suited for street rods / "g" machines. 4 links are best suited for drag /race cars ( much more instant center adjust ability for track conditions).
Fastest 300
#2408233 - 11/24/17 10:57 AM Re: 4 link suspension [Re: Crizila]
AZ_A12_BEE Offline
R.
Mine will be street so you suggest a 4 bar over a 4 link?
#2408357 - 11/24/17 03:34 PM Re: 4 link suspension [Re: AZ_A12_BEE]
Crizila Offline
Loc: Az
R.
Yes, especially if you have any kind of room constraint issues, which street rods often have.
Fastest 300
25,538 Registered Members
194,127 Topics
Video: Mopar Releases Teaser For 2018 SEMA Show
by Rustymuscle
19 minutes 19 seconds ago
really expensive and odd Dodge Ram Daytona
by Butterscotch71
46 minutes 51 seconds ago
Funding new business startups
by feets
Today at 12:11 PM
Radio
by ct440rod
Today at 11:45 AM
