Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310688
05/25/17 12:22 AM
05/25/17 12:22 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Just my opinion but it looks maybe a 10% better package to a comparable older engine up to a point. Mainly cubic inches, once over 450 cubes no matter how good the heads flow, once over that number the big cubes should be faster, easier to build, and at a lower rpm. Now if they make a block that can go 500 ci and over (can't see that happening with the bore spacing) no contest.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310689
05/25/17 12:25 AM
05/25/17 12:25 AM
Tacoma, Washington USA
Adam71Charger Offline
Originally Posted By pittsburghracer
Originally Posted By cudadoug
QUOTE: But deals like this are far and few for the new stuff on the market.
Could be the wedge stuff had a 30+ year head start?
At least. LOL. Loving it more everyday.
I think that was my point. Lots of people know the old small blocks and big blocks very well, know what to look for, and can do a lot of the more intricate work themselves. Same with guys who run the newer stuff. I was just trying to compare actual ballpark prices to build a turn key motors for guys who only know basic mechanics and buy pretty much everything off the shelf.
I personally prefer the old stuff and you and other members on this site have helped me save money and time building my engines. But I would like to collect parts as I come along them to build a g3, I think it wound be fun.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310843
05/25/17 11:40 AM
05/25/17 11:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lets see those time slips...Proof is ALWAYS in the math. SHow me a weight and timeslip NA. Aint hard to figure the power then. not saying I am not open to new stuff by any means, lord knows a lot of what I do it "outside the box" for most of the Mopar crowd. But dyno numbers that are not backed up by timeslip data mean very little.
I am all for the development of the Gen 3 stuff. I am just not dumping a BB and going that way right now. GOnna have to show me. And I see sone VERY LOFTY guesses as to the potential power NA. Making 1000hp is not a simple task for any NA engine let alone a SB limited cube piece. Believe me I work with a small cube 1000+hp piece all the time
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Al_Alguire] #2310856
05/25/17 12:07 PM
05/25/17 12:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
A few guys have posted their time slips, NA they're in the 145+ mph range from the couple I took 5 minutes to look for. Per Wallace that puts them around 750-800 hp. One was a 468 Thiteck headed Magnum. Weighed 3250. Used a 6.1 intake, 12:1, not sure of the cam
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310860
05/25/17 12:17 PM
05/25/17 12:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And I wonder what those 750-800hp NA engines cost. Since that seems to be one of the matters in question. Didn't realize what you posted was NA...My bad
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310872
05/25/17 12:43 PM
05/25/17 12:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The 468 is an aftermarket aluminum block motor. Totally unecessary and a big expense for a Gen III unless you're wanting to cut weight, factory blocks are more than adequate. Thiteks aren't cheap, but I'd venture to guess you could get the cfm needed from an Apache/Big Gas/HellCat head. The 468 I posted wasn't maxed out, it was still using a factory intake (ported) and 12:1, room for more compression and a better intake
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: WO23Coronet] #2310943
05/25/17 02:11 PM
05/25/17 02:11 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Thiteks are not expensive for a brand new CNC ported cylinder head! Depending on how you get them, bare castings to fully assembled, they are around $2500-3500. I got mine for $2850...Ported Castings with Stainless Valves, ready to assemble. I had my own springs locks & retainers etc.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Al_Alguire] #2310952
05/25/17 02:28 PM
05/25/17 02:28 PM
STEFF Offline
STEFF  Offline
Al,
These motors cost the same to build as it does a good small or big block of that HP caliber......$15-20+ grand. Like I tell everyone, Good parts cost good money, regardless of what you build. The disadvantage to this platform compared to the others is there is not alot of used inventory of high caliber parts floating around, like with the big blocks, small blocks, Gen 2 Hemis etc.... You want to build a stout NA deal, get ready to pay just like you would any other motor, if you do not have anything to start with.
NOBODY is making 700+ HP NA with these motors, with junkyard core and some bolt ons. Power adders, that's another story.....
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: moparmitch] #2310971
05/25/17 02:55 PM
05/25/17 02:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By moparmitch
The newer VVT engines are not as desirable as you have to deal with the cam phasing garb and related camshaft. In production form they seem to make good power for what they are, but they would not be a first choice for a traditional power build up to swap parts on to.
I need a motor for my ride and I'm stuck between a 440 based setup or possibly a G3 based platform. I've considered a 6.4 Apache motor, but to run a simple carb and MSD box, would require the goofy cam phaser "locking" (and still using stock timing set) along with a manifold swap. And then there's the MDS junk and the MDS lifters which would need to go. Along with that, then new valve springs and pushrods would be the right thing to do...this adds up quick, not to mention all the time involved. You would have to get a really good deal on a VVT motor to cover all the band-aid fixes to make it barely reasonable for a high performance N/A breather. Of course, this doesn't really matter for an EFI forced induction.
It seems as though the greatly demonstrated pre VVT block buildups are still the way to go for a G3 performance motor. Just look at Dustin's build to see the successful and well proven approach.
Notice the the engine masters stroker buildups all use non VVT based motors.
I also agree with the statement that a G3 vs BB build will cost similar for a 600-700HP build. I've run the numbers too and its about a wash with all things considered.
I'm still very intrigued by the G3 and would like to move to this platform...we'll see
my two cents...
VVT is soooo easy to delete, remove 4 screws on the phaser and stick something, almost anything, in the oil chamber to prevent it from moving and bolt it back together. With very little ingenuity you can even use it as an easy advance retard mechanisim instead of buying a very expensive adjustable timing set, just shim the cam forward and backward in the same oil chamber to set it where you want it.
If MDS bothers you gen a manual trans engine. If you find a screamin deal on a used one with MDS and you want to ditch it, well MDS is easy peasy also, just leave the solenoids in and don't plug em in and wa la, no MDS. You do not need to buy new lifters to delete MDS.
Neither one costs any money to eliminate.
Plus if you are planning to go the "don't touch the long block" method you get a slightly better rod (a little more meat where the 08 back would snap)and piston (lower ring friction due to thinner rings and the top ring is a little farther down) in the 09+ engines.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2311009
05/25/17 04:07 PM
05/25/17 04:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Steff you confirm pretty much what I suspected. Just cannot imagine it being a cheaper endeavor at all. Possibly better stock pieces available but many of us have moved well past stock anything these days.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Al_Alguire] #2311183
05/25/17 09:40 PM
05/25/17 09:40 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have been drinking the coolaid on this, collecting parts. I agree good parts cost comparable money.
A lot of it is about what the goals are. For me racing is a way of keeping myself amused and getting rid of excess cash and time.
If looking for sound investments a race engine is not were I would put my money laugh2
"Just a Bracket car dressed up like a streetcar"
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2311235
05/25/17 11:02 PM
05/25/17 11:02 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
You cant compare aftermarket offerings against factory for all out racing.
The gen3 is the best factory offering from mopar but its not near the aftermarket bb offerings.
KB is working on the gen 3 so who knows what the future holds though
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: The Shadow] #2311258
05/25/17 11:35 PM
05/25/17 11:35 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Oh they are? That's not what I heard
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2311289
05/26/17 12:24 AM
05/26/17 12:24 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Apparently that was one of the goals of the reorg at KB but who knows.....
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: WO23Coronet] #2311343
05/26/17 01:58 AM
05/26/17 01:58 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Thitek head is not just a copy of a stock head. Its port is raised and will outflow any of the factory heads. Plus you can run a dual valve spring making it far better for what we need to do.
That 468 has the 2.20 titanium valve Thitek heads on it. Ported stock 6.1 intake is extremely good. Long runners but still flows very well. And you can only build an engine that big with a factory block if you darton sleeve it.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2311400
05/26/17 08:56 AM
05/26/17 08:56 AM
jersey
Spaceman Spiff Offline
jersey
I wonder how many late model mopars are out there running swapped in big blocks....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Spaceman Spiff] #2311484
05/26/17 12:37 PM
05/26/17 12:37 PM
Washington
madscientist Offline
Washington
How would it pass emissions?
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: madscientist] #2311496
05/26/17 12:55 PM
05/26/17 12:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
My 493 10.5-1, 590 mopar cam, edel rpm heads 600hp
Upgraded to indy ez and solid roller made around 720hp
426 6.1 base. Eagle heads. 10.5-1, .600 lift hyd cam 620ish hp
That upgrade on the BB cost alot of money. I put aluminum caps in the motor when I upgraded because I got "nervous". Roller cam and everything that goes with it. Very spendy. Going over that 600 mark seems to get much more expensive
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: madscientist] #2311515
05/26/17 01:35 PM
05/26/17 01:35 PM
jersey
jersey
Race cars don't have to pass emissions.....
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2311557
05/26/17 02:55 PM
05/26/17 02:55 PM
fredericksburg,va
fredericksburg,va
i think it would be easier tracking down a problem with the older stuff being so simple. Watching the SO the other nite and this one dude was saying something about one " level" ? being out and would have to leave at full throttle, maybe blowing the tires off. Sounds like he needs three guys (10 years olds) with lap tops just to run each round. I race by myself and don't like the hassle, THE reason I sold my fast car.
