FiTech fuel filter, what and where? #2308718
05/21/17 09:22 PM
05/21/17 09:22 PM
BDW Online content OP
BDW  Online Content OP
Finishing up my FiTech install, currently have a Mustang fuel filter laying near frame rail.
What did you guys use and where did you mount it?
Re: FiTech fuel filter, what and where? [Re: BDW] #2308746
05/21/17 09:45 PM
05/21/17 09:45 PM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
with fuel injection you should put a screen mesh filter, 20 micron, BEFORE the pump and a fine paper, 100 micron, somewhere AFTER the pump and before the injectors and regulators.
perception is 90% of reality
Re: FiTech fuel filter, what and where? [Re: BDW] #2308782
05/21/17 10:24 PM
05/21/17 10:24 PM
I should have added:
I have the Spectra EFI tank with the in-tank fuel pump.
Re: FiTech fuel filter, what and where? [Re: BDW] #2309028
05/22/17 01:19 PM
05/22/17 01:19 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I am using an Edelbrock -6AN 40 micron filter on the Holley terminator.
BTW, I do have the Madhu pulse width regulator operating in a non return environment running 45psi to the throttle body.
Craig
Re: FiTech fuel filter, what and where? [Re: Mr T2U] #2309980
05/23/17 08:17 PM
05/23/17 08:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is backwards and IMO you should never a paper filter especially with fuel injection.
Re: FiTech fuel filter, what and where? [Re: BDW] #2310064
05/23/17 11:25 PM
05/23/17 11:25 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Fitech calls for 58 psi.
This is the prefilter I am using, SUM-230106.
The fuel pump,SUM-250111,mounted below the fuel cell.
The filter near the throttle bodies,SUM-230116-B.
Re: FiTech fuel filter, what and where? [Re: moparborn] #2310308
05/24/17 12:40 PM
05/24/17 12:40 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The Spectra tank has a built in pump with built in sock filter. That is why I am just using a 40 micron filter in line with the injectors. My filter is under the hood inline with the fuel supply to the injectors. The pressure gauge to activate the PWM is on a T on the outlet of the EFI with a cap on the end. This is where the mechanical bypass regulator was hooked up but it is not needed now. I am also using this sensor on the Megasquirt so I can monitor and log fuel pressure.
Craig
Re: FiTech fuel filter, what and where? [Re: BDW] #2311215
05/25/17 10:29 PM
05/25/17 10:29 PM
FYI for anyone looking at this, I ended up getting the standard filter used in my 06 Mustang and found this clamp on Amazon.
Less than $30 for both, I couldn't see paying almost $100 for the same thing from Aeromotive.
