Big Block Distrbutor Shaft #2309887
05/23/17 04:40 PM
05/23/17 04:40 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Changed cam. Primed oil pump . Now drive shaft won't go down into oil pump all the way. Still a good ways from even engaging drive gear on cam. Feels like it's bottoming out before it's all the way in. I suppose something happened while priming....? Anyone have a clue?!?!?!
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Big Block Distrbutor Shaft [Re: Texas383] #2309892
05/23/17 04:51 PM
05/23/17 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Use your priming rod to turn the pump a little and then try installing the intermediate shaft again. If no go, repeat.
Re: Big Block Distrbutor Shaft [Re: John_Kunkel] #2309899
05/23/17 05:13 PM
05/23/17 05:13 PM
Chicago
PurpleBeeper Offline
Chicago
I agree. You're trying to line up BOTH the hex end of the drive shaft & the gears on the cam. It sounds like one of those two is off slightly and John's idea would work just fine.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Big Block Distrbutor Shaft [Re: PurpleBeeper] #2309905
05/23/17 05:21 PM
05/23/17 05:21 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yep. Or you can rotate the engine with a breaker bar slowly. This will rotate the cam gear and intermediate shaft until the hex lines up with the oil pump.
Two ways to do the same thing. Good luck.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Big Block Distrbutor Shaft [Re: Texas383] #2309915
05/23/17 05:43 PM
05/23/17 05:43 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I will give it a try. Thanx!
1969 Y2 Super Bee
Re: Big Block Distrbutor Shaft [Re: Texas383] #2309952
05/23/17 07:02 PM
05/23/17 07:02 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Remember when it starts to go in it wants to rotate counterclockwise as it drops.
Re: Big Block Distrbutor Shaft [Re: Dave Hall] #2309964
05/23/17 07:38 PM
05/23/17 07:38 PM
If turning the hex with the priming rod don't do it (likely it will) you might loosen the pump housing slightly so you can get a dead on hex alignment & I always do that when going together.
Re: Big Block Distrbutor Shaft [Re: Texas383] #2310109
05/24/17 12:19 AM
05/24/17 12:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Also keep in mined that when the #1 cylinder is at top dead center the slot in the oil pump drive gear should be facing straight front to back of the engine. If not. you'll have to re do the plug wires to where the rotor is pointing. Do it right , less confusing later.
