Big Block Distrbutor Shaft
#2309887
05/23/17 04:40 PM
05/23/17 04:40 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
Changed cam. Primed oil pump . Now drive shaft won't go down into oil pump all the way. Still a good ways from even engaging drive gear on cam. Feels like it's bottoming out before it's all the way in. I suppose something happened while priming....? Anyone have a clue?!?!?!
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Big Block Distrbutor Shaft
[Re: Texas383]
#2309892
05/23/17 04:51 PM
05/23/17 04:51 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Use your priming rod to turn the pump a little and then try installing the intermediate shaft again. If no go, repeat.
[Re: John_Kunkel]
#2309899
05/23/17 05:13 PM
05/23/17 05:13 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I agree. You're trying to line up BOTH the hex end of the drive shaft & the gears on the cam. It sounds like one of those two is off slightly and John's idea would work just fine.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2309905
05/23/17 05:21 PM
05/23/17 05:21 PM
Posts: 3,386 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I agree. You're trying to line up BOTH the hex end of the drive shaft & the gears on the cam. It sounds like one of those two is off slightly and John's idea would work just fine. Yep. Or you can rotate the engine with a breaker bar slowly. This will rotate the cam gear and intermediate shaft until the hex lines up with the oil pump. Two ways to do the same thing. Good luck.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Texas383]
#2309915
05/23/17 05:43 PM
05/23/17 05:43 PM
Texas383
Marshall TX
I will give it a try. Thanx!
[Re: Dave Hall]
#2309964
05/23/17 07:38 PM
05/23/17 07:38 PM
RapidRobert
If turning the hex with the priming rod don't do it (likely it will) you might loosen the pump housing slightly so you can get a dead on hex alignment & I always do that when going together.
[Re: Texas383]
#2310109
05/24/17 12:19 AM
05/24/17 12:19 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Also keep in mined that when the #1 cylinder is at top dead center the slot in the oil pump drive gear should be facing straight front to back of the engine. If not. you'll have to re do the plug wires to where the rotor is pointing. Do it right , less confusing later.
