Proper Kickdown adjustment for 1 piece rod on 727 #2301156
05/08/17 02:00 PM
05/08/17 02:00 PM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
Having read the thread under Moparmacka's "727 T/F THROTTLE LINKAGE ADJUSTMENT???", I realized I was having a related issue. Although my upshifts between 1-2 and 2-3 are crisp and evenly timed culminating in a 2 to 3 up shift at about 25 mph, I can't seem to get any downshifting when approaching a turn or coming to a stop until the car is almost completely stopped. Is this normal or do I still have to play around with the throttle rod to get some automatic downshifting to happen shruggy ?
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301160
05/08/17 02:06 PM
05/08/17 02:06 PM
your year of 727 may not have part throttle kickdown (it can be added into the VB) but wait for Kunkel & others who have more info/know for sure.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: RapidRobert] #2301177
05/08/17 02:29 PM
05/08/17 02:29 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
From 71-90 Chrysler RWD Haynes Manual
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: NachoRT74] #2301183
05/08/17 02:39 PM
05/08/17 02:39 PM
Ottawa, Ontario
Ottawa, Ontario
has anyone ever bought or fabricated the adjusting tool displayed in image 5.5 of the manual that was just posted? Also, I'm a little concerned about where it mentions at the top of the section that damage to transmission can result if kickdown adjustment is not done properly. How fast will damage occur if your only out by a fraction of an inch on the throttle adjuster but you're still getting good upshifts?
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301189
05/08/17 02:49 PM
05/08/17 02:49 PM
as fast as your upshifts are coming in you are in no danger of hurting it from it slipping from too little psi. On the tool possibly a pair of needle nose vice grips & some rag to protect the shank from its' serrations (if they are just wanting it held in position, might need a helper to hold it).
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301204
05/08/17 03:37 PM
05/08/17 03:37 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think that tool is stated for 6 cylinders only ?
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: NachoRT74] #2301211
05/08/17 03:47 PM
05/08/17 03:47 PM
Ottawa, Ontario
Ottawa, Ontario
The image doesn't correspond to the paragraph header above it that mentions the 6 cylinders. The image is correct for any 727 with a 1 piece throttle rod I think.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: NachoRT74] #2301213
05/08/17 03:55 PM
05/08/17 03:55 PM
Ottawa, Ontario
Ottawa, Ontario
I just went back to read all of the sections and you're right! For V8 applications using a 1 piece rod, it starts at illustration 5.15 and they don't mention any sort of tool or special contraption to hook up to make the adjustment. You just take the slack off the rod and retainer and then make your adjustment.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301216
05/08/17 03:59 PM
05/08/17 03:59 PM
Ottawa, Ontario
Ottawa, Ontario
Thank you Nacho RT74!
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301275
05/08/17 06:03 PM
05/08/17 06:03 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
You never answered the question in the first reply; depending on the year, it's perfectly normal to have no downshift when turning as corner or rolling to a stop.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301313
05/08/17 07:34 PM
05/08/17 07:34 PM
Ottawa, Ontario
Ottawa, Ontario
Apologies. it's a 1971 Plymouth B Body.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301317
05/08/17 07:45 PM
05/08/17 07:45 PM
Rio Linda, CA
Rio Linda, CA
OK, depending on the engine, it might have part throttle kickdown (PTK) which means the trans could shift down from 3rd to 2nd at low speed with the application of some throttle (less than full throttle) but it won't shift down just coasting to a stop until almost fully stopped.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301361
05/08/17 09:27 PM
05/08/17 09:27 PM
Ottawa, Ontario
Ottawa, Ontario
John, I have a 383-300HP in my R/R. Should I be looking for a 3-2 downshift at some point during deceleration or does that condition not happen?
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301656
05/09/17 11:43 AM
05/09/17 11:43 AM
California
biggE Offline
biggE  Offline
California
1971 was the first year for the part throttle kickdown as far s I know. I have a 71 383 A/T car and it works fine. I know that the valve body is the original. If your trans is the original but had previous work done to it the valve body might not be original and could be an earlier year.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: biggE] #2301698
05/09/17 12:49 PM
05/09/17 12:49 PM
Ottawa, Ontario
Ottawa, Ontario
As far as I know, the transmission in my car is the original. I've never experienced a downshift from 3-2 when slowing down to take a corner only on part throttle acceleration it'll kickdown to 2nd. I've always had to downshift manually when taking a corner to match RPMs with speed. Would that be normal?
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301843
05/09/17 05:06 PM
05/09/17 05:06 PM
Rio Linda, CA
Rio Linda, CA
The 727 won't drop from 3-2 on deceleration, it drops from 3-1 when the speed is low enough. The reason for this is to prevent the lurch that would accompany the 3-2 downshift...since there is no coast braking in 1st gear in Drive, there is no lurch as it shifts down when rolling to a stop.
If it kicks down to 2nd with part throttle when rounding a corner, it has PTK.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: John_Kunkel] #2301904
05/09/17 06:43 PM
05/09/17 06:43 PM
Ottawa, Ontario
Ottawa, Ontario
Then I'm pretty convinced that I don't have PTK based on your explanation.
Is PTK available as a kit to be added to the valve body? It seems to me that this would be a useful feature to have for the type of driving that I do. At least for me. Another poster had suggested that it may be.
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: L.R Helbling] #2301907
05/09/17 06:53 PM
05/09/17 06:53 PM
Rio Linda, CA
Rio Linda, CA
Generally speaking, the PTK wasn't installed on HP transmissions but it can be retrofitted. The parts in the link below will convert any '71-later trans to PTK:
http://www.ebay.com/itm/Torqueflite-727-...s-/371729024490
Re: Proper Kickdown adjustment for 1 piece rod on 727 [Re: John_Kunkel] #2301960
05/09/17 08:19 PM
05/09/17 08:19 PM
Ottawa, Ontario
Ottawa, Ontario
Thanks John. I appreciate it.
