Re: Proper Kickdown adjustment for 1 piece rod on 727
[Re: L.R Helbling]
#2301160
05/08/17 02:06 PM
05/08/17 02:06 PM
RapidRobert
your year of 727 may not have part throttle kickdown (it can be added into the VB) but wait for Kunkel & others who have more info/know for sure.
[Re: RapidRobert]
#2301177
05/08/17 02:29 PM
05/08/17 02:29 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
From 71-90 Chrysler RWD Haynes Manual
[Re: NachoRT74]
#2301183
05/08/17 02:39 PM
05/08/17 02:39 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
From 71-90 Chrysler RWD Haynes Manual has anyone ever bought or fabricated the adjusting tool displayed in image 5.5 of the manual that was just posted? Also, I'm a little concerned about where it mentions at the top of the section that damage to transmission can result if kickdown adjustment is not done properly. How fast will damage occur if your only out by a fraction of an inch on the throttle adjuster but you're still getting good upshifts?
[Re: L.R Helbling]
#2301189
05/08/17 02:49 PM
05/08/17 02:49 PM
RapidRobert
as fast as your upshifts are coming in you are in no danger of hurting it from it slipping from too little psi. On the tool possibly a pair of needle nose vice grips & some rag to protect the shank from its' serrations (if they are just wanting it held in position, might need a helper to hold it).
[Re: L.R Helbling]
#2301204
05/08/17 03:37 PM
05/08/17 03:37 PM
NachoRT74
Valencia, España
I think that tool is stated for 6 cylinders only ?
[Re: NachoRT74]
#2301211
05/08/17 03:47 PM
05/08/17 03:47 PM
L.R Helbling
Ottawa, Ontario
I think that tool is stated for 6 cylinders only ? The image doesn't correspond to the paragraph header above it that mentions the 6 cylinders. The image is correct for any 727 with a 1 piece throttle rod I think.
[Re: NachoRT74]
#2301213
05/08/17 03:55 PM
05/08/17 03:55 PM
L.R Helbling
Ottawa, Ontario
I think that tool is stated for 6 cylinders only ? I just went back to read all of the sections and you're right! For V8 applications using a 1 piece rod, it starts at illustration 5.15 and they don't mention any sort of tool or special contraption to hook up to make the adjustment. You just take the slack off the rod and retainer and then make your adjustment.
[Re: L.R Helbling]
#2301275
05/08/17 06:03 PM
05/08/17 06:03 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You never answered the question in the first reply; depending on the year, it's perfectly normal to have no downshift when turning as corner or rolling to a stop.
[Re: L.R Helbling]
#2301317
05/08/17 07:45 PM
05/08/17 07:45 PM
John_Kunkel
Rio Linda, CA
OK, depending on the engine, it might have part throttle kickdown (PTK) which means the trans could shift down from 3rd to 2nd at low speed with the application of some throttle (less than full throttle) but it won't shift down just coasting to a stop until almost fully stopped.
[Re: biggE]
#2301698
05/09/17 12:49 PM
05/09/17 12:49 PM
L.R Helbling
Ottawa, Ontario
1971 was the first year for the part throttle kickdown as far s I know. I have a 71 383 A/T car and it works fine. I know that the valve body is the original. If your trans is the original but had previous work done to it the valve body might not be original and could be an earlier year. As far as I know, the transmission in my car is the original. I've never experienced a downshift from 3-2 when slowing down to take a corner only on part throttle acceleration it'll kickdown to 2nd. I've always had to downshift manually when taking a corner to match RPMs with speed. Would that be normal?
[Re: L.R Helbling]
#2301843
05/09/17 05:06 PM
05/09/17 05:06 PM
John_Kunkel
Rio Linda, CA
The 727 won't drop from 3-2 on deceleration, it drops from 3-1 when the speed is low enough. The reason for this is to prevent the lurch that would accompany the 3-2 downshift...since there is no coast braking in 1st gear in Drive, there is no lurch as it shifts down when rolling to a stop.
If it kicks down to 2nd with part throttle when rounding a corner, it has PTK.
[Re: John_Kunkel]
#2301904
05/09/17 06:43 PM
05/09/17 06:43 PM
L.R Helbling
Ottawa, Ontario
Then I'm pretty convinced that I don't have PTK based on your explanation. Is PTK available as a kit to be added to the valve body? It seems to me that this would be a useful feature to have for the type of driving that I do. At least for me. Another poster had suggested that it may be.
