thoughts on 11 inch front brakes - extra parts #2295814
04/28/17 10:30 PM
04/28/17 10:30 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I ordered rebuild kits for the front drums on the 69 rr. It came with extra parts. Should I install just what the brake/ drum had ? Any pics of completed layout/ drum laying around so I can see wheat it should be. Thanks -
68 Satellite Wagon and a few other ones
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2295822
04/28/17 10:55 PM
04/28/17 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
extra parts?
Such as?
Don't be the exception.
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2295832
04/28/17 11:10 PM
04/28/17 11:10 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Pictures would help a lot
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2295834
04/28/17 11:11 PM
04/28/17 11:11 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Maybe the self adjuster parts?
Re: thoughts on 11 inch front brakes - extra parts [Re: CompSyn] #2295836
04/28/17 11:13 PM
04/28/17 11:13 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Most likely but we need pictures
Re: thoughts on 11 inch front brakes - extra parts [Re: Morty426] #2296264
04/29/17 10:41 PM
04/29/17 10:41 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
did I do this right ? the blue spring is the extra part ???
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296275
04/29/17 10:49 PM
04/29/17 10:49 PM
All looks good in the pic. that blue one is a return spring. they (2 of em) go from the upper part of the shoe web at a ~45 deg angle up to the anchor at 12 O clock. One extra got thrown in by mistake, possibly one for another app?. I'm assuming you got (4) in your kit.
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296285
04/29/17 11:09 PM
04/29/17 11:09 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I got 8 springs in the kit. 4 browns which I used two at the top of the shoes, 2 green, which you see in the pictures, and then 2 of these stubby blue ones - the browns looked pretty much the same
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296286
04/29/17 11:12 PM
04/29/17 11:12 PM
when you can, post a pic of everything. we'll get it figured out.
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296287
04/29/17 11:15 PM
04/29/17 11:15 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I just did the 10 inch brakes on the wagon and I put a "disc" under the silver spring on either side of the shoes - the first springs you connect with the pin through the backing plate. This kit didn't have those - so I have the spring touching the shoe. is that acceptable ?
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296288
04/29/17 11:17 PM
04/29/17 11:17 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
pic of brown springs > done right ?
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296289
04/29/17 11:19 PM
04/29/17 11:19 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Also - the oval plate that you put on the top post - which then the adjuster goes over - and then the springs - I had 2 types - the ones I used you can see, and larger ones - does it matter ?
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296291
04/29/17 11:20 PM
04/29/17 11:20 PM
I don't see a problem with that.
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296334
04/30/17 12:42 AM
04/30/17 12:42 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Are the last 2 pictures the same or both sides, if both sides you have the brake shoes on backwards
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296353
04/30/17 02:11 AM
04/30/17 02:11 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
They look like the same pic.
Joe
Re: thoughts on 11 inch front brakes - extra parts [Re: jlatessa] #2296393
04/30/17 08:09 AM
04/30/17 08:09 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
the short brake shoes always goes to the front of the vehicle, so If the photos is a passenger side assembly it should work.
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296394
04/30/17 08:28 AM
04/30/17 08:28 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Right, adjusters to the rear, short shoes to front.
Just looks like a double post to me.
Angry white pureblood male
Re: thoughts on 11 inch front brakes - extra parts [Re: mro] #2296430
04/30/17 11:27 AM
04/30/17 11:27 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
Should have 4 round discs. One goes between the spring and the shoe.
It keeps the pin located.
