thoughts on 11 inch front brakes - extra parts
#2295814
04/28/17 10:30 PM
04/28/17 10:30 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
I ordered rebuild kits for the front drums on the 69 rr. It came with extra parts. Should I install just what the brake/ drum had ? Any pics of completed layout/ drum laying around so I can see wheat it should be. Thanks -
68 Satellite Wagon and a few other ones
Re: thoughts on 11 inch front brakes - extra parts
[Re: CompSyn]
#2295836
04/28/17 11:13 PM
04/28/17 11:13 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Maybe the self adjuster parts? Most likely but we need pictures
[Re: Morty426]
#2296264
04/29/17 10:41 PM
04/29/17 10:41 PM
mro
Lynch Road
did I do this right ? the blue spring is the extra part ???
[Re: mro]
#2296275
04/29/17 10:49 PM
04/29/17 10:49 PM
RapidRobert
All looks good in the pic. that blue one is a return spring. they (2 of em) go from the upper part of the shoe web at a ~45 deg angle up to the anchor at 12 O clock. One extra got thrown in by mistake, possibly one for another app?. I'm assuming you got (4) in your kit.
[Re: mro]
#2296285
04/29/17 11:09 PM
04/29/17 11:09 PM
mro
Lynch Road
I got 8 springs in the kit. 4 browns which I used two at the top of the shoes, 2 green, which you see in the pictures, and then 2 of these stubby blue ones - the browns looked pretty much the same
[Re: mro]
#2296286
04/29/17 11:12 PM
04/29/17 11:12 PM
RapidRobert
when you can, post a pic of everything. we'll get it figured out.
[Re: mro]
#2296287
04/29/17 11:15 PM
04/29/17 11:15 PM
mro
Lynch Road
I just did the 10 inch brakes on the wagon and I put a "disc" under the silver spring on either side of the shoes - the first springs you connect with the pin through the backing plate. This kit didn't have those - so I have the spring touching the shoe. is that acceptable ?
[Re: mro]
#2296288
04/29/17 11:17 PM
04/29/17 11:17 PM
mro
Lynch Road
pic of brown springs > done right ?
[Re: mro]
#2296289
04/29/17 11:19 PM
04/29/17 11:19 PM
mro
Lynch Road
Also - the oval plate that you put on the top post - which then the adjuster goes over - and then the springs - I had 2 types - the ones I used you can see, and larger ones - does it matter ?
[Re: mro]
#2296291
04/29/17 11:20 PM
04/29/17 11:20 PM
RapidRobert
I don't see a problem with that.
[Re: mro]
#2296334
04/30/17 12:42 AM
04/30/17 12:42 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Are the last 2 pictures the same or both sides, if both sides you have the brake shoes on backwards
[Re: mro]
#2296394
04/30/17 08:28 AM
04/30/17 08:28 AM
Posts: 5,919 ohio
ruderunner
ohio
Right, adjusters to the rear, short shoes to front.
Just looks like a double post to me.
Angry white pureblood male
