Pics of flooded heads what would you do? #229517
02/19/09 02:30 AM
02/19/09 02:30 AM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
They sat in water for 7 days. machine shop says new springs and lap the valves and seats>never run
I had the cam ground for the stock springs that came with them.
Would it be ok to just order new springs, retainers and don't they have a cup under the springs?Change them and clean up the hardened seats with a Red Scotch Brite Pad
560/575 244/252@ 0.050
This is the worse of the 2 the other is not bad at all.But would do what ever to both.
Was told to get Hughes 1111 or Comp Cams 987 what reatiners and cups under the springs should I get? Sorry to keep posting stupid questions
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads002.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads003.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads004.jpg
And the one that is not no way near as bad
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads005.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads006.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Flood%20Heads/FloodHeads007.jpg
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229518
02/19/09 02:38 AM
02/19/09 02:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i changed out the eddy springs for the hughes 1111 and used the eddy retainers.
or if you need new retainers ...you can just use the one hughes refer to at their website.
Tony
70 AARCuda Vitamin C
Re: Pics of flooded heads what would you do? [Re: 70AARcuda] #229519
02/19/09 02:44 AM
02/19/09 02:44 AM
340SIX Offline OP
340SIX  Offline OP
Are all retainers the same or does the angle of the locks matter?
I have no idea what it is since is stock eddie heads with a port job and gasket match as well as the intake
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229520
02/19/09 03:00 AM
02/19/09 03:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the retainers need to match the stem size of the valves which are 11/32 on the eddies..
i reused the retainers and the locks on the eddies..
if you buy new ones...the retainers are hughes pn 1203 or 1202 and locks are 1322..
Tony
Re: Pics of flooded heads what would you do? [Re: 70AARcuda] #229521
02/19/09 08:42 AM
02/19/09 08:42 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I would take them apart. Wire wheel the pieces and put them back together.
It's just a little rust.
Re: Pics of flooded heads what would you do? [Re: The Shadow] #229522
02/19/09 12:11 PM
02/19/09 12:11 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
a dip in miuratic acid would do the trick.
Re: Pics of flooded heads what would you do? [Re: The Shadow] #229523
02/19/09 01:12 PM
02/19/09 01:12 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
X2
Maybe hand lap the valves and run it.
Re: Pics of flooded heads what would you do? [Re: 1Bad440] #229524
02/19/09 01:58 PM
02/19/09 01:58 PM
340SIX Offline OP
340SIX  Offline OP
I was told I could be taking a large chance of the springs braking.
It does not look like they have a cup under the springs to keep them from diging into the aluminum head must be a washer?
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229525
02/19/09 03:05 PM
02/19/09 03:05 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I've never seen any Hughes springs come in here that had'nt lost alot of pressure, in fact I just had to replace all 16 valves in a set of E heads that were in such bad float from the Hughes 1111 springs dying. Also they make you run some goofy shim for the inner spring if you are not running on a stock style J/X head that has a spring step on it, those shims were wearing & pumping metal out. I'll leave it at that since I don't want to start a pissing match.
The 987 Comp's are a little light on the seat for my liking. I'd probably put a set of 978-16 Comp's in it installed at 1.80", ~145 on seat, ~360 open.....use a Comp 741-16 moly 10 degree retainer, & a set of 611-16 Comp locks. Fresh valve job, & install new spring shims or do it right & machine the spring pockets & add a seat locator/cup. I'd use a 4704-16 Comp OD cup if it was me....
When they do the VJ, have the seats intentionally sunk .030" for flow & will help give more room for the thicker .060" locator.
Factory E heads come with single springs with a damper around 110 on seat 280 open, 7 degree retainers & stamped steel 7 degree locks, no cup/loctaor, just some unhardened spring shims under them. Usually a .030" & a .015" depending on how head was machined.
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229526
02/19/09 03:05 PM
02/19/09 03:05 PM
Connecticut
5126brl No more Offline
Connecticut
looks like longer than 7 days!
Re: Pics of flooded heads what would you do? [Re: 5126brl No more] #229527
02/19/09 03:31 PM
02/19/09 03:31 PM
340SIX Offline OP
340SIX  Offline OP
They were in plastic bags that had holes in them. it was just 7 days. When I called eddlebrock
They said the stock spring as set up new are good to .580 lift.
I was going just go back with what I had before unless it is a bad idea thus me asking here.
I have someone who took the whole factory set off his brand new never run, that I can get from him at a good price.
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229528
02/19/09 03:42 PM
02/19/09 03:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Take'em apart Scotch Brite the parts, clean up everything, reassemble. As long as No real bad pitting can be seen
Re: Pics of flooded heads what would you do? [Re: Bob_Coomer] #229529
02/19/09 03:52 PM
02/19/09 03:52 PM
340SIX Offline OP
340SIX  Offline OP
Mostly worried that I am doing the right thing staying with the stock springs that came with them.Sincle I can just change them out for another set just like them.
And the seats being rusted,just looking in the holes the rust looks like it would clean off with ared scotch brite pad and oil.
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229530
02/19/09 04:10 PM
02/19/09 04:10 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
What brand is the cam, ie I need to know how fast the ramp profile is, if it is a Hughes or something with a .904" Chrysler fast lobe on it I would not run the stock E head springs on it, they're just not up to the task pressure wise. Just because a spring can "handle" .580" lift does not mean it has enough pressure to deal with fast ramp speed or heavy valvetrain.
Re: Pics of flooded heads what would you do? [Re: RyanJ] #229531
02/19/09 04:24 PM
02/19/09 04:24 PM
340SIX Offline OP
340SIX  Offline OP
Engle Soild KV2-3 it is a combo of both the KV2 and KV3
Lift 560/575 lash .018/0.20
Duration at 0.050 244/252
lobe centers 110
card says overlap
TDC Intake Opens 11 Exhaust Closes 16
BDC Intake Closes 53 Exhaust Opens 56
Running Duration 275/284
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229532
02/19/09 05:39 PM
02/19/09 05:39 PM
Connecticut
Connecticut
Stop being CHEAP!! Just send them out and stimulate the economy...
Re: Pics of flooded heads what would you do? [Re: 5126brl No more] #229533
02/19/09 05:44 PM
02/19/09 05:44 PM
340SIX Offline OP
340SIX  Offline OP
Me Cheap?
Hey I gave my son 10 bucks to clean up the worse looking one! It is nice as before I have been teaching him how to sand/polish stuff. But he says ther is no real money in it for the time it takes to do it! Plus no normal person wants that done
Re: Pics of flooded heads what would you do? [Re: 340SIX] #229534
02/19/09 10:10 PM
02/19/09 10:10 PM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
if they were mine, like others said, i would if anything get new springs/ retainers, and just scotbrite all the rust off the valves, and seats etc.
theyll be good as new
Re: Pics of flooded heads what would you do? [Re: SealockRacing] #229535
02/19/09 10:38 PM
02/19/09 10:38 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I'd have Ryan set you up with the right springs/retainers/locks and install height. You don't want to mess around with that stuff. Those are critical valve train components. Failure there could be catastrophic.
Re: Pics of flooded heads what would you do? [Re: 69Cuda340S] #229536
02/20/09 12:14 AM
02/20/09 12:14 AM
340SIX Offline OP
340SIX  Offline OP
I called engle and eddlebrock both said the stock stuff would be ok! I wanted to check incase I was told wrong when this was done the first time! They both said it would be fine with the same thing I had before.
But was also almost at limit but the factory stuff supplied would be fine.
Someone like Ryan who see them when the new wears off so to say, would Know if they will hold up to the test of time. As he stated about the 1111 huges ones don't.I wonder how the stock ones supplied with the heads hold up?
I was planing on changing the whole mess{springs,locks and retainers.
Under the springs looks to be a brass or copper colored washers not cuped shape that is not rust and looks nothing like the ones listed here Spring Cups
One head looks to have no damage at all.
