Lifter bore back spot facing tool needed #2295022
04/27/17 02:22 PM
04/27/17 02:22 PM
South Louisiana
DBCooper Offline OP
DBCooper  Offline OP
South Louisiana
Hello everyone !
I need to buy or rent a tool to back spot face the lifter bores in my block so I can run mushroom style lifters.
Anyone have one or know of one ?
Thank you in advance !!!
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295180
04/27/17 06:53 PM
04/27/17 06:53 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
No, but I have yet to hear from anyone who had to do it (despite the old Direct Connection bible saying so). Put the lifters in, then the cam, and see if the cam can be turned!
One person posted that it's a good idea in case you float a lifter sufficiently to hit the underside of the block. Mine are miles away (well, at least 1/4") at max lift so I didn't bother. But I do run a rev limiter laugh
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295181
04/27/17 06:59 PM
04/27/17 06:59 PM
South Louisiana
DBCooper Offline OP
DBCooper  Offline OP
South Louisiana
Which cam do you run ? I plan on using the old Mini Express.
Thank you for your reply
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295195
04/27/17 07:24 PM
04/27/17 07:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Who are you talking to.. I dont see any reply..
I ran a old mushroom tappet years ago.. the old
.750 lift.. but I had a shop do it back then.. as
I didnt have the tools to do it
wave
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295205
04/27/17 07:36 PM
04/27/17 07:36 PM
AndyF Offline
AndyF  Offline
I used to have one of those tools but I haven't used it in 20 years so I'm not sure which tool box it is in.
If I recall I bought that tool from a regular machine tool vendor. It is a fairly standard tool called a back spot facer or something like that. I think MSC has them in the catalog for $30 or something like that.
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295296
04/27/17 10:01 PM
04/27/17 10:01 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's the one (316 adv/0.654", .024/.028 lash) P3690588 Mini-Express. I got a used one so I sent it to Schneider to have the lobe taper restored. They measured it at 278 @.050. After regrinding it was 272 @.050, .652 lift, .018/.018 lash so actually a bit more lift than stock and slightly less duration.
If I ever get my Dart out of paint jail, I'll let you know how it runs!
drive
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295304
04/27/17 10:26 PM
04/27/17 10:26 PM
Kirkland, Washington
Pacnorthcuda Offline
DBCooper...do you have any old weathered US currency you would like to exchange for new?
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295377
04/28/17 12:05 AM
04/28/17 12:05 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
haha
Re: Lifter bore back spot facing tool needed [Re: MR_P_BODY] #2295699
04/28/17 05:22 PM
04/28/17 05:22 PM
South Louisiana
DBCooper Offline OP
DBCooper  Offline OP
South Louisiana
wave
I was talking to DrCharles lol
Re: Lifter bore back spot facing tool needed [Re: Pacnorthcuda] #2295700
04/28/17 05:24 PM
04/28/17 05:24 PM
South Louisiana
DBCooper Offline OP
DBCooper  Offline OP
South Louisiana
Actually I collect old paper, paper monies and coins. Love gold and silver bullion
Re: Lifter bore back spot facing tool needed [Re: AndyF] #2295701
04/28/17 05:29 PM
04/28/17 05:29 PM
South Louisiana
DBCooper Offline OP
DBCooper  Offline OP
South Louisiana
I will continue my search with machine shop tooling sales. If you could find yours, I would be glad to buy it from you.
Re: Lifter bore back spot facing tool needed [Re: DBCooper] #2295714
04/28/17 06:17 PM
04/28/17 06:17 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Check to see if you really need it. I didn't 35 years ago when I ran the mini express.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
