Re: 8.75 Center section
[Re: Dr Dave]
#2291324
04/20/17 11:50 PM
04/20/17 11:50 PM
RapidRobert
thats alot of dough (even eBay is cheaper than that), way more than I would pay, you might put an add in your local CL for a 742 sure grip pig in the ratio you are after. or the ads here or on FABO.
[Re: ahy]
#2291404
04/21/17 02:08 AM
04/21/17 02:08 AM
Posts: 4,693 Wichita
GY3
Wichita
I bought one from them a few years ago. They come with the crappy Auburn units and it looked like someone went after the side adjusters with a claw hammer! I had well over $1300 in mine IIRC. I'm putting down some decent power and using drag radials so that may account for the sure-grip going away fairly quickly, but they are a poor design and simply don't last long term.
[Re: Dr Dave]
#2291578
04/21/17 02:26 PM
04/21/17 02:26 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Talk to Dr Diff a member here.One of the best when it comes to diffs.Rocky
Chrysler Firepower
[Re: therocks]
#2291622
04/21/17 03:36 PM
04/21/17 03:36 PM
dogdays
Id also suggest starting out with a call to DoctorDiff. He has new nodular iron cases and everything to go inside them: http://www.doctordiff.com/8-3-4-489-case-third-member.htmlHis price is $1375 with everything new, Nodular case, Powr Lock, gears, all set up. The nodular case is important as it is 50% stiffer than a common cast iron case. Adding his partlist prices I come up with $1041. Throw in $175 for gear setup time and $200 profit and there's your price. With something like that you get what you pay for. In my local Craigslist I am seeing used 8 3/4s with "Posi" to be a little more than $500. That's all greasy, just pulled out of the axle and set in a can. R. In your shoes I'd be looking for a Dana 60.
[Re: Dr Dave]
#2291657
04/21/17 05:07 PM
04/21/17 05:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dr Diff is out of 8 3/4's right now.
So the choice is S60.
[Re: Paul_Fancsali]
#2291704
04/21/17 06:39 PM
04/21/17 06:39 PM
Posts: 21,837 Kirkland, Washington
Pacnorthcuda
The cone units were the best years ago but after 50+ years they are now JUNK Never had much issue with a cone unit I had then now the sure grip is going away Dated 1965 but after all this time guess I 'll have to take care of it Ummm...no. The cone units were NEVER the best. The power lock (powr-lok) pre dates the cone unit and was a far better design, then and now.
[Re: Dr Dave]
#2291999
04/22/17 10:04 AM
04/22/17 10:04 AM
Posts: 1,771 Jamestown, Indiana
James74
Jamestown, Indiana
I bit on this deal. After sourcing what it would cost to get mine rebuilt locally, plus parts, plus the time to run everything around, I figured it wasn't too bad of a price. At $1400 plus $300 for new axles I was contemplating stepping up to a dana, but for my car I don't think its necessary. Mancini hasn't been real helpful about shipping charges and stuff, so hopefully they don't gouge on that, and the quality is good...
