8.75 Center section #2291313
04/20/17 11:37 PM
04/20/17 11:37 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Mancini is advertising all new 8.75 center section with choice of ratios for $1175.00. Is that a good deal?
Re: 8.75 Center section [Re: Dr Dave] #2291324
04/20/17 11:50 PM
04/20/17 11:50 PM
thats alot of dough (even eBay is cheaper than that), way more than I would pay, you might put an add in your local CL for a 742 sure grip pig in the ratio you are after. or the ads here or on FABO.
Re: 8.75 Center section [Re: Dr Dave] #2291326
04/20/17 11:53 PM
04/20/17 11:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Guess that would mean we can't say "They are not making them anymore" now.
Seeing some of the prices some of the old original well geared center sections were bringing, that price is probably not out of line. Of course, they won't ever be numbers matching.
Now, if someone is making new housings.... Gene
Re: 8.75 Center section [Re: Dr Dave] #2291330
04/20/17 11:57 PM
04/20/17 11:57 PM
Kirkland, Washington
Pacnorthcuda Offline
Difference between new and take your chances used.
Whatever you do, don't buy a cone unit.
Re: 8.75 Center section [Re: Pacnorthcuda] #2291374
04/21/17 01:17 AM
04/21/17 01:17 AM
IN
ahy Offline
ahy  Offline
IN
I think that price is fair if made with good parts. I did not pay much less 15 years ago for a new clutch type sure grip center section.
Re: 8.75 Center section [Re: ahy] #2291404
04/21/17 02:08 AM
04/21/17 02:08 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought one from them a few years ago. They come with the crappy Auburn units and it looked like someone went after the side adjusters with a claw hammer! I had well over $1300 in mine IIRC. I'm putting down some decent power and using drag radials so that may account for the sure-grip going away fairly quickly, but they are a poor design and simply don't last long term.
'63 Dodge 330
11.19 @ 121 mph
Re: 8.75 Center section [Re: GY3] #2291523
04/21/17 12:37 PM
04/21/17 12:37 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I rebuilt one about 10 years ago with a Richmond 3.55 and auburn cone style SG. Haven't had any problems with it but I don't drag race the car either.
Re: 8.75 Center section [Re: Dr Dave] #2291578
04/21/17 02:26 PM
04/21/17 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Talk to Dr Diff a member here.One of the best when it comes to diffs.Rocky
Chrysler Firepower
Re: 8.75 Center section [Re: therocks] #2291622
04/21/17 03:36 PM
04/21/17 03:36 PM
dogdays Offline
dogdays  Offline
Id also suggest starting out with a call to DoctorDiff. He has new nodular iron cases and everything to go inside them:
http://www.doctordiff.com/8-3-4-489-case-third-member.html
His price is $1375 with everything new, Nodular case, Powr Lock, gears, all set up. The nodular case is important as it is 50% stiffer than a common cast iron case. Adding his partlist prices I come up with $1041. Throw in $175 for gear setup time and $200 profit and there's your price.
With something like that you get what you pay for.
In my local Craigslist I am seeing used 8 3/4s with "Posi" to be a little more than $500. That's all greasy, just pulled out of the axle and set in a can.
R.
In your shoes I'd be looking for a Dana 60.
Re: 8.75 Center section [Re: Dr Dave] #2291636
04/21/17 04:04 PM
04/21/17 04:04 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
^ good post.
A guy here was selling a 489 case with 3.91 gears and what looked like a powerlock, but the ring gear was missing a bunch of teeth. he wanted $300.
also, good point on the D60, doctor diff has the strange dana 60's for about $2150. that seems like a great deal considering a new 8.75 third member is basically $1400...
Re: 8.75 Center section [Re: Dr Dave] #2291657
04/21/17 05:07 PM
04/21/17 05:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dr Diff is out of 8 3/4's right now.
So the choice is S60.
Don't be the exception.
Re: 8.75 Center section [Re: Dr Dave] #2291661
04/21/17 05:09 PM
04/21/17 05:09 PM
P
Paul_Fancsali Offline
P
The cone units were the best years ago but after 50+ years they are now JUNK Never had much issue with a cone unit I had then now the sure grip is going away Dated 1965 but after all this time guess I 'll have to take care of it
Re: 8.75 Center section [Re: Paul_Fancsali] #2291704
04/21/17 06:39 PM
04/21/17 06:39 PM
Ummm...no. The cone units were NEVER the best. The power lock (powr-lok) pre dates the cone unit and was a far better design, then and now.
Re: 8.75 Center section [Re: Dr Dave] #2291770
04/21/17 08:31 PM
04/21/17 08:31 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Thanks for everyone's thoughts!
Re: 8.75 Center section [Re: Dr Dave] #2291999
04/22/17 10:04 AM
04/22/17 10:04 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
I bit on this deal. After sourcing what it would cost to get mine rebuilt locally, plus parts, plus the time to run everything around, I figured it wasn't too bad of a price. At $1400 plus $300 for new axles I was contemplating stepping up to a dana, but for my car I don't think its necessary. Mancini hasn't been real helpful about shipping charges and stuff, so hopefully they don't gouge on that, and the quality is good...
Re: 8.75 Center section [Re: James74] #2292240
04/22/17 06:04 PM
04/22/17 06:04 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
You have a PM. up
