Which way does the filler tube seal install? #2283380
04/06/17 03:10 PM
04/06/17 03:10 PM
BDW Offline OP
BDW  Offline OP
*** Follow-up at bottom of thread ***
I got this improved design gas tube seal. Did a search and found answers indicating both directions?
So does the rounded side face out or inside of the tank?
Thx
Re: Which way does the filler tube seal install? [Re: BDW] #2283393
04/06/17 03:39 PM
04/06/17 03:39 PM
None
71rm23 Offline
71rm23  Offline
None
I'd put the rounded facing out. Flat side to the tank
Re: Which way does the filler tube seal install? [Re: BDW] #2283403
04/06/17 03:51 PM
04/06/17 03:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call the manufacturer and ask them thumbs scope Please post what you find out on here so more people will know from your findings up work
Re: Which way does the filler tube seal install? [Re: BDW] #2283430
04/06/17 04:37 PM
04/06/17 04:37 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Is there a directional lip inside? If so I would install it with it pointing inside, sorta like a front or rear main seal. shruggy
Re: Which way does the filler tube seal install? [Re: Cab_Burge] #2283434
04/06/17 04:45 PM
04/06/17 04:45 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Saved this when I bought mine.
Just like 71rm23 said, flat side against the tank.
Re: Which way does the filler tube seal install? [Re: CDN72SE] #2283562
04/06/17 08:05 PM
04/06/17 08:05 PM
On mine I had the flat side outside, now sure (now) if that is correct but it did fit/no leaks.
Re: Which way does the filler tube seal install? [Re: CDN72SE] #2283609
04/06/17 10:24 PM
04/06/17 10:24 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
X3
Re: Which way does the filler tube seal install? [Re: BDW] #2283621
04/06/17 10:50 PM
04/06/17 10:50 PM
BDW Offline OP
BDW  Offline OP
Thx for the replies, my plan is to:
- install grommet in tank, round lip out (no RTV or sealer needed?)
- install the rubber floor pan gasket on filler tube (Challenger)
- partially install tank with straps, let it hang down
- slide tube down through floor pan into tank, lubed grommet with silicon beforehand
- tighten up straps holding tank
- pull tube back up to mount to qtr panel
Sound right?
Re: Which way does the filler tube seal install? [Re: RapidRobert] #2283776
04/07/17 05:19 AM
04/07/17 05:19 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Same here. Several hard launches and never leaked a drop of fuel. Thought it acted like a baffle and it kept pressure off the "main" seal.
Re: Which way does the filler tube seal install? [Re: BDW] #2283794
04/07/17 09:11 AM
04/07/17 09:11 AM
BDW Offline OP
BDW  Offline OP
DMT (manufacturer of the seal) responded to my question:
"The rounded side goes into the tank"
Now I'm confused, what's right?
This might actually makes more sense, extra seal area inside tank.
Re: Which way does the filler tube seal install? [Re: BDW] #2283799
04/07/17 09:35 AM
04/07/17 09:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
6 of one, half dozen of the other.
Re: Which way does the filler tube seal install? [Re: bonefish] #2283815
04/07/17 10:08 AM
04/07/17 10:08 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Install the neck to car and and the boot to the trunk floor then grease up the seal and slide the gas tank on . It usually doesn't work to good putting the tank in first . And the round side of the seal goes in as there is a bevel on the other side to help start the neck in.
Re: Which way does the filler tube seal install? [Re: FY1TA] #2283837
04/07/17 11:02 AM
04/07/17 11:02 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm not sure about this particular seal but look at the lips on the ID. Which way would the filler neck slide in the easiest? That's typically the way the seal is installed. As a comment, the FSM for the later rides recommends using power steering fluid as an assembly lube and that's what I've used in the past.
Re: Which way does the filler tube seal install? [Re: BDW] #2284351
04/08/17 12:07 PM
04/08/17 12:07 PM
BDW Offline OP
BDW  Offline OP
Follow-up:
Right or wrong, I'm installing it with rounded side in for 3 reasons
1) Stock tank is installed that way. May have been replaced over the years, but factory PN is on flat side, seems logical they would want this visible
2) Flat side has beveled opening, easier to insert tube without damaging seal
3) Rounded side has smaller opening, this is the extra sealing from earlier design, seems extra seal should be inside tank, not outside after a leak of primary seal
Re: Which way does the filler tube seal install? [Re: BDW] #2286202
04/12/17 01:39 AM
04/12/17 01:39 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By cnxt
Follow-up:
Makes perfect sense to me.
