Which way does the filler tube seal install?
#2283380
04/06/17 03:10 PM
04/06/17 03:10 PM
Posts: 4,751 Florida
BDW
*** Follow-up at bottom of thread *** I got this improved design gas tube seal. Did a search and found answers indicating both directions? So does the rounded side face out or inside of the tank? Thx
Re: Which way does the filler tube seal install?
[Re: BDW]
#2283403
04/06/17 03:51 PM
04/06/17 03:51 PM
Posts: 43,287 Bend,OR USA
Cab_Burge
[Re: CDN72SE]
#2283562
04/06/17 08:05 PM
04/06/17 08:05 PM
RapidRobert
On mine I had the flat side outside, now sure (now) if that is correct but it did fit/no leaks.
[Re: CDN72SE]
#2283609
04/06/17 10:24 PM
04/06/17 10:24 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Saved this when I bought mine.
Just like 71rm23 said, flat side against the tank.
X3
[Re: RapidRobert]
#2283776
04/07/17 05:19 AM
04/07/17 05:19 AM
Posts: 270 Missouri
Big_E
Missouri
On mine I had the flat side outside, now sure (now) if that is correct but it did fit/no leaks. Same here. Several hard launches and never leaked a drop of fuel. Thought it acted like a baffle and it kept pressure off the "main" seal.
[Re: bonefish]
#2283815
04/07/17 10:08 AM
04/07/17 10:08 AM
Posts: 1,890 In the 8's
FY1TA
In the 8's
Install the neck to car and and the boot to the trunk floor then grease up the seal and slide the gas tank on . It usually doesn't work to good putting the tank in first . And the round side of the seal goes in as there is a bevel on the other side to help start the neck in.
[Re: FY1TA]
#2283837
04/07/17 11:02 AM
04/07/17 11:02 AM
Posts: 10,756 North Dakota
6PakBee
North Dakota
I'm not sure about this particular seal but look at the lips on the ID. Which way would the filler neck slide in the easiest? That's typically the way the seal is installed. As a comment, the FSM for the later rides recommends using power steering fluid as an assembly lube and that's what I've used in the past.
[Re: BDW]
#2284351
04/08/17 12:07 PM
04/08/17 12:07 PM
BDW
Follow-up: Right or wrong, I'm installing it with rounded side in for 3 reasons 1) Stock tank is installed that way. May have been replaced over the years, but factory PN is on flat side, seems logical they would want this visible 2) Flat side has beveled opening, easier to insert tube without damaging seal 3) Rounded side has smaller opening, this is the extra sealing from earlier design, seems extra seal should be inside tank, not outside after a leak of primary seal
[Re: BDW]
#2286202
04/12/17 01:39 AM
04/12/17 01:39 AM
6PakBee
North Dakota
Follow-up: Right or wrong, I'm installing it with rounded side in for 3 reasons 1) Stock tank is installed that way. May have been replaced over the years, but factory PN is on flat side, seems logical they would want this visible 2) Flat side has beveled opening, easier to insert tube without damaging seal 3) Rounded side has smaller opening, this is the extra sealing from earlier design, seems extra seal should be inside tank, not outside after a leak of primary seal Makes perfect sense to me.
