Page 2 of 3 1 2 3
Re: Holley Street Dominator modification [Re: TonyS451] #2235298
01/16/17 02:12 PM
01/16/17 02:12 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Originally Posted By TonyS451
I know Streetwize has done some modifications and testing on a street dominator intake. Maybe he will chime in and post some pics. I followed his suggestions and home modified one a few years ago. Most of the work was in the plenum area and blend into the runners. I never personally did any before or after testing, but the plenum area does have a lot
of material that can be removed for a smoother shot to the runners.
Did the same thing myself with Streetwize help.
Re: Holley Street Dominator modification [Re: BradH] #2235302
01/16/17 02:22 PM
01/16/17 02:22 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
One more pic that shows the plenum of my Hughes plenum-modified RB M1 intake. This is NOT how it came from Hughes, and I ended up putting quite a bit more time into the intake, primarily runner sizing and entry work.
Re: Holley Street Dominator modification [Re: Rob C] #2235383
01/16/17 04:05 PM
01/16/17 04:05 PM
Washington
madscientist Offline
Washington
Originally Posted By Rob C
Originally Posted By madscientist
The SD looks like it will take a TQ but it won't. So it isn't actually a spread bore intake or a square bore.
Street or Strip Dominator?
I have a "B" Street Dominator that is a spread and works with a TQ and the correct TQ gasket.
I meant Strip Dominator. Sorry for the kornfusion.
I have never checked a BB intake to see if the TQ fits, but I've never seen a TQ fit the Strip Dominator without modifications, and sometimes welding.
Re: Holley Street Dominator modification [Re: BradH] #2235390
01/16/17 04:13 PM
01/16/17 04:13 PM
Washington
Washington
That's what I do.
I only do it if it port the entire intake, because the times I have tested it, if you don't do it all, there is almost no power.
And I've tested it both ways...porting the intake without fixing the top and fixing the top without porting. There is always a gain when you do both.
I typed that out and confused myself. If you separate it all out, you need to port the intake to see any benefit to fixing the top. At least in my testing. I've seen 35-40 HP from just porting the intake and another 12-15 from fixing the top. Also, the tune up is easier when you fix the top.
I charge $850 to port the intake and weld the top. It's a PITA but it's worth it. Convincing guys to do it is another thing.
Re: Holley Street Dominator modification [Re: fast68plymouth] #2235412
01/16/17 04:43 PM
01/16/17 04:43 PM
BradH Offline
BradH  Offline
Originally Posted By fast68plymouth
I still have it, and I probably flowed it at some point, but don't recall any of that info.
It wouldn't flow as well as, or likely make as much power as a Victor with an adapter for a 4500.
This is another one of those "I'd have to go digging for the paperwork to be sure" things, but IIRC we tested that intake w/ a standard 1050 Dominator during our last dyno session, and it made about the same power as your CFS annular 4150 on my plenum-ported Victor did... 620+ HP & 580-ish torque?
It was just a quick swap and no time was spent trying to tune the 1050, which I seem to recall as showing a bit lean when I looked over the A/F ratios on the printout later. scope
Re: Holley Street Dominator modification [Re: TonyS451] #2235586
01/16/17 09:02 PM
01/16/17 09:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Bobby loaned me a Street Dominator that I tested last summer. Back to back weekends as cast vs. ported, I consistently picked up a 1/10 in e.t. and 1 mph. I purchased it and it is on my car now. Translates to 12-ish HP?
'63 Dodge 330
11.19 @ 121 mph
Re: Holley Street Dominator modification [Re: GY3] #2239606
01/23/17 01:57 AM
01/23/17 01:57 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
I bought another Street Dominator this evening. My plan is to modify this one when it comes in and do back to back testing against one that has had no modifications. Good chance I'll throw them on the flow bench as well. I'll report back with my findings. Just give me some time though, the cars are a bit back on the priority list right now. -Trent up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Holley Street Dominator modification [Re: MadMopars] #2273175
03/20/17 06:45 PM
03/20/17 06:45 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Got my intake back from the machinist today. up I had him weld up the intake plenum and close up the EGR holes that were left when I cut the EGR garbage off. I'll keep you guys updated as things progress.
Re: Holley Street Dominator modification [Re: DGS] #2273580
03/21/17 11:32 AM
03/21/17 11:32 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Looks great! Are you going to smooth the transition from the car flange to the plenum a bit?
Re: Holley Street Dominator modification [Re: DGS] #2274076
03/22/17 02:22 AM
03/22/17 02:22 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
That's the plan. It'll be a couple weeks before I get around to it though. The transmission in our daily driver took a crap so I'm elbow deep in that project right now. Mix that with being in the air conditioning industry this time of year and free time is a bit hard to come by.
I'll keep you guys posted though as I make progress. I'll be anxious to compare the two intakes to see how much the mods are really worth. up
Re: Holley Street Dominator modification [Re: DGS] #2274231
03/22/17 02:11 PM
03/22/17 02:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice looking work on that intake so far.
It'll be interesting to see what kind of difference you see in track performance.
Re: Holley Street Dominator modification [Re: fast68plymouth] #2274636
03/23/17 03:14 AM
03/23/17 03:14 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Thanks! up
Re: Holley Street Dominator modification [Re: MadMopars] #2274816
03/23/17 02:56 PM
03/23/17 02:56 PM
BradH Offline
BradH  Offline
I see a LOT of sawzall in your future.
Re: Holley Street Dominator modification [Re: BradH] #2275159
03/24/17 01:36 AM
03/24/17 01:36 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
True story. violin
It wouldn't be so bad if it weren't aluminum. I probably spend as much time cleaning the bits as I do actually grinding. I was told to try bar soap on the bits to prevent loading them up with aluminum. Anybody have any other suggestions or know if there's any truth to the soap trick?
Re: Holley Street Dominator modification [Re: MadMopars] #2275211
03/24/17 02:55 AM
03/24/17 02:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
True story. violin
Sounds like your bits are too fine.. but you
can use WD40 also.. either spray them or get a
small bucket and dip the bits in and let them
drip off for a minute then use it.. I just spray
them but it cost a touch more this way
wave
Re: Holley Street Dominator modification [Re: DGS] #2275213
03/24/17 02:57 AM
03/24/17 02:57 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Soap trick works!
Re: Holley Street Dominator modification [Re: Rob C] #2275215
03/24/17 03:07 AM
03/24/17 03:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Soap trick works!
I use to use soap when I was cutting a lot of
alum with a circular saw(I use to build Burger
Kings and did the windows so I did a lot of alum
cutting.. but I use WD when grinding alum.. but
the bits have to be right also.. fine will load
up pretty easy.. but a course but wants to catch
wave
Re: Holley Street Dominator modification [Re: MadMopars] #2275220
03/24/17 03:24 AM
03/24/17 03:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
True story. violin
I did some SERIOUS work on a W-9 intake.. it was
the first one cast and they were gonna pitch it
so I grabbed it and started playing with it.. it
was easier to cut it in half to work on it then
weld it back together
EDIT
I modified this to fit a dominator which wasnt
normally done
wave
Re: Holley Street Dominator modification [Re: MR_P_BODY] #2300984
05/08/17 01:27 AM
05/08/17 01:27 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Just a quick update...
I spent some time this afternoon blending the runners into the plenum. The picture doesn't do it much justice, nor am I finished but the corners are coming along.
I'm leaning towards thinning the dividers down a bit but will probably try to keep them more rounded than knife edged. I was told knife edging was actually worse for flow although I personally haven't tested that theory.
I missed your last post Mr. P but I can imagine cutting the intake in half made things a ton easier to work on. Part of me wants to keep track of how many hours I'll have in this intake, the other half doesn't. Hope it's worth the hassle in the end. Time will tell I suppose.
Re: Holley Street Dominator modification [Re: MadMopars] #2300990
05/08/17 01:41 AM
05/08/17 01:41 AM
Washington
Washington
Coming along nicely. Make sure the port has some taper. It should be bigger at the plenum than at the flange. Not sure you can get as much as you need without more welding, but get what you can.
Page 2 of 3 1 2 3
