Who is running a Titan oil pump
#2273475
03/21/17 02:11 AM
03/21/17 02:11 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Like it says who out there is using one of the Titan oil pumps. And if you are are you running it as a single or dual line set up. Two -16 feed lines seems to be a tad overkill. Just curious
Re: Who is running a Titan oil pump
[Re: Al_Alguire]
#2273515
03/21/17 08:04 AM
03/21/17 08:04 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I have one. I use 2 -12 lines. I like it, it is externally adjustable for the relief valve pressure. It will not lose it's prime like a milodon pump does.
[Re: Al_Alguire]
#2273609
03/21/17 12:37 PM
03/21/17 12:37 PM
Posts: 4,457 Washington
madscientist
Washington
It's hard to get the inlet side of a pump too big.
[Re: Al_Alguire]
#2273674
03/21/17 02:11 PM
03/21/17 02:11 PM
Al_Alguire
Las Vegas
Well I ran a Charlie Wescott pump on the Cuda and one -16 single line. Bearings always looked new on freshen up. Frankly I have never run dual anything not even on a mildon or Indy pump. A simgle -12 has been sufficient in those for me. A -12 is a 5/8" internal diameter which seems like plenty.
[Re: Al_Alguire]
#2273721
03/21/17 03:36 PM
03/21/17 03:36 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
My motor isn't near the level of the stuff you run Al, but I have also just run a single -12 line w/ Milodon pumps and the bearings always look great.
[Re: an8sec70cuda]
#2273734
03/21/17 03:55 PM
03/21/17 03:55 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do you guys still run the dual line swinging pick up and just block one side off or go a different route
[Re: Al_Alguire]
#2273737
03/21/17 04:04 PM
03/21/17 04:04 PM
an8sec70cuda
I use a single static pickup w/ a standard chassis center sump style pan.
[Re: Al_Alguire]
#2273744
03/21/17 04:10 PM
03/21/17 04:10 PM
Al_Alguire
Las Vegas
Single static has always worked for me in a drag car. But I also always click it off at the stripe.
[Re: Al_Alguire]
#2273757
03/21/17 04:24 PM
03/21/17 04:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Single static has always worked for me in a drag car. But I also always click it off at the stripe. You wont have any issue with that size line.. if you did you would be out of oil in the pan.. and your not
[Re: Al_Alguire]
#2274323
03/22/17 04:42 PM
03/22/17 04:42 PM
Al_Alguire
Las Vegas
Ran a single -16 on the Cuda for a very long time. Had well over 1000 passes on it and was never an issue with oil pressure or running out. This is a B1 engine as was the Cuda. Biggest issue is getting oil back to the pan. We will keep the vacuum down somewhat to help with drainback and let it eat.
