Who is running a Titan oil pump #2273475
03/21/17 02:11 AM
03/21/17 02:11 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Like it says who out there is using one of the Titan oil pumps. And if you are are you running it as a single or dual line set up. Two -16 feed lines seems to be a tad overkill. Just curious
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273515
03/21/17 08:04 AM
03/21/17 08:04 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have one. I use 2 -12 lines. I like it, it is externally adjustable for the relief valve pressure. It will not lose it's prime like a milodon pump does.
Re: Who is running a Titan oil pump [Re: Bigcube] #2273516
03/21/17 08:07 AM
03/21/17 08:07 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Pic of pump.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273609
03/21/17 12:37 PM
03/21/17 12:37 PM
Washington
madscientist Offline
Washington
It's hard to get the inlet side of a pump too big.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273623
03/21/17 01:01 PM
03/21/17 01:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Two -12 lines in and a single -10 out and a single 5/8" engine passage. I can see where too big is just pointless.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273674
03/21/17 02:11 PM
03/21/17 02:11 PM
Las Vegas
Las Vegas
Well I ran a Charlie Wescott pump on the Cuda and one -16 single line. Bearings always looked new on freshen up. Frankly I have never run dual anything not even on a mildon or Indy pump. A simgle -12 has been sufficient in those for me. A -12 is a 5/8" internal diameter which seems like plenty.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273721
03/21/17 03:36 PM
03/21/17 03:36 PM
an8sec70cuda Offline
My motor isn't near the level of the stuff you run Al, but I have also just run a single -12 line w/ Milodon pumps and the bearings always look great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Who is running a Titan oil pump [Re: an8sec70cuda] #2273734
03/21/17 03:55 PM
03/21/17 03:55 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Do you guys still run the dual line swinging pick up and just block one side off or go a different route
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273737
03/21/17 04:04 PM
03/21/17 04:04 PM
I use a single static pickup w/ a standard chassis center sump style pan.
CHIP
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273740
03/21/17 04:06 PM
03/21/17 04:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Single line with a stockish high volume pump on my stuff.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273744
03/21/17 04:10 PM
03/21/17 04:10 PM
Las Vegas
Las Vegas
Single static has always worked for me in a drag car. But I also always click it off at the stripe.
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2273757
03/21/17 04:24 PM
03/21/17 04:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You wont have any issue with that size line.. if you did you
would be out of oil in the pan.. and your not
wave
Re: Who is running a Titan oil pump [Re: Al_Alguire] #2274323
03/22/17 04:42 PM
03/22/17 04:42 PM
Las Vegas
Las Vegas
Ran a single -16 on the Cuda for a very long time. Had well over 1000 passes on it and was never an issue with oil pressure or running out. This is a B1 engine as was the Cuda. Biggest issue is getting oil back to the pan. We will keep the vacuum down somewhat to help with drainback and let it eat.
