Re: 727 thrust washer trouble(again)
[Re: 67_Satellite]
#2260125
02/26/17 10:12 PM
02/26/17 10:12 PM
Posts: 12,306 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have beat that thrust washer out before. Lost high gear one time.
I use the bearing and washers from A&A now. You have to take .060 off a shaft to make room for it, but it puts that issue to bed.
I think I beat mine out by manual shifting on the street. Winding it up in low, then snapping it when it went into second.
Master, again and still
[Re: 67_Satellite]
#2260381
02/27/17 11:59 AM
02/27/17 11:59 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you believe that the converter was being pushed back that far, make sure that you check your front pump. I have one in the shop right now that had the converter pushed back too far. It ruined the pump and we had to have the housing machined to get the grooves out.
[Re: 67_Satellite]
#2260426
02/27/17 12:56 PM
02/27/17 12:56 PM
Thumperdart
State of confusion
My builder Darryl Parks uses thrust bearings and are in mine now going on a year beating spree............
