Re: INDY valve covers/breather/MSD dist questions
[Re: Project kickin A]
#2260118
02/26/17 10:06 PM
02/26/17 10:06 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
PkA,,,,,that looks nice ! Thanks for the picture,,,no clearance issues with the distributor,,, Nice motor shot !!! Doug
[Re: 69CHARGERMD]
#2260430
02/27/17 01:01 PM
02/27/17 01:01 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Here's what I use Doc. 440 w/ Indy SR heads and Indy valve covers. MSD pro billet distributor...I did have to slightly clearance the valve cover to clear the distributor. Very light clearance, no biggy. I have 1.5 ratio Harland Sharp roller rockers w/ a .700" lift roller cam.
For "breathers" I just use a -10an hose off each valve cover that "T" into a breather tank. The weld-on bung fittings on the valve covers are not baffled at all, just open underneath. I really like this setup. Vents the motor very well and no leaks. Open breathers will put oil all over the place and vacuum pumps are a pain in the rear.
[Re: an8sec70cuda]
#2262215
03/02/17 04:02 PM
03/02/17 04:02 PM
69CHARGERMD
KENTUCKY
Thanks Chip ! Looks like the breather tank is next to the rad on the passenger front fender... I assume you just drain it as needed,,, I like the breather idea if it will keep the mess down under the hood. Do you have to run baffles ?? ( not sure ) Thanks for the tip on the distributor,,,always looks tight to me,,but didn't want to do alot of grinding on the VC. Thanks again Doug
[Re: 69CHARGERMD]
#2262232
03/02/17 04:41 PM
03/02/17 04:41 PM
an8sec70cuda
The tank hardly ever needs to be drained. Usually just gets some condensation in it. There are no baffles in or under the fittings on the valve covers. Just drilled a hole and welded on the -10an bung. I just made sure the hole was in between the first pair of rocker arms. I just had to clearance the valve cover a little to clear the distributor, not the cyl. head.
[Re: Airwoofer]
#2262261
03/02/17 05:55 PM
03/02/17 05:55 PM
an8sec70cuda
I love the way most pics show the logo milled off on the valve covers. I did mine also, as well as the intake.
LOL, yep. Mine had the logo when new, but I set them up on the DCM head surfacer and cut em smooth. Wish I had a milling machine to smooth out the manifold too.
[Re: 69CHARGERMD]
#2263561
03/05/17 05:07 AM
03/05/17 05:07 AM
Posts: 102 Australia
Project kickin A
Australia
PkA,,,,,that looks nice ! Thanks for the picture,,,no clearance issues with the distributor,,, Nice motor shot !!! Doug No, its a little tight like everyone elses but no biggie
