INDY valve covers/breather/MSD dist questions #2259826
02/26/17 02:40 PM
02/26/17 02:40 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
INDY valve covers ( 440 )
1) What breathers are you guys using ?
2) Did you use a particular aftermarket set up?
3) Any advice on where to drill the valve covers ( front or back
4) Any issues with rocker arm clearance or hitting ? ( Harland Sharp rockers )
5) MSD billet distributor ?? will this clear the INDY covers ?
6) Is there a small and regular size MSD distributor to choose from if VC clearance is a issue ?
Thx
Doug
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2259869
02/26/17 03:25 PM
02/26/17 03:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Breathers are a matter of personal choise,we put both sides up front if possible.We have not had any clearance issues with MSD distributer and most all aftermarket rockers.With the MSD distributer just index the cap so that the hold down screws are away from the valve cover.
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2259871
02/26/17 03:26 PM
02/26/17 03:26 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Indy valve covers on 440-1s clear the MSD billet distributor (RB). That may be different for other brand heads. I use a remote breather. No rocker clearance problem (T&Ds) with the weld-on bung, and no more oil dripping on the headers.
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2259924
02/26/17 04:29 PM
02/26/17 04:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
run of the mill chrome breathers
I use the billet adapters available from Jegs, etc.
drill so the covers are interchangeable - rear on the left, front on the right
HS rockers here - no issues
Clearing the head is more of an issue. My Indys are an early set that were not machined for dist clearance but my billet Firecore clears. Can't see the MSD being any different.
Shouldn't be an issue.
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2259936
02/26/17 04:46 PM
02/26/17 04:46 PM
KENTUCKY
KENTUCKY
Thanks everyone for the feedback,,,very helpful ! ( appreciate the pictures too )
Doug wink
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2260074
02/26/17 08:54 PM
02/26/17 08:54 PM
Australia
P
Project kickin A Offline
P
Australia
I used Harland Sharp rockers on my S/Rs and have a baffle plate welded under my Mr Gasket breathers no oil leaks
Re: INDY valve covers/breather/MSD dist questions [Re: Project kickin A] #2260118
02/26/17 10:06 PM
02/26/17 10:06 PM
KENTUCKY
KENTUCKY
PkA,,,,,that looks nice !
Thanks for the picture,,,no clearance issues with the distributor,,,
Nice motor shot !!!
Doug smile
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2260430
02/27/17 01:01 PM
02/27/17 01:01 PM
an8sec70cuda Offline
Here's what I use Doc. 440 w/ Indy SR heads and Indy valve covers. MSD pro billet distributor...I did have to slightly clearance the valve cover to clear the distributor. Very light clearance, no biggy.
I have 1.5 ratio Harland Sharp roller rockers w/ a .700" lift roller cam.
For "breathers" I just use a -10an hose off each valve cover that "T" into a breather tank. The weld-on bung fittings on the valve covers are not baffled at all, just open underneath. I really like this setup. Vents the motor very well and no leaks.
Open breathers will put oil all over the place and vacuum pumps are a pain in the rear.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: INDY valve covers/breather/MSD dist questions [Re: an8sec70cuda] #2262215
03/02/17 04:02 PM
03/02/17 04:02 PM
KENTUCKY
KENTUCKY
Thanks Chip !
Looks like the breather tank is next to the rad on the passenger front fender...
I assume you just drain it as needed,,,
I like the breather idea if it will keep the mess down under the hood.
Do you have to run baffles ?? ( not sure )
Thanks for the tip on the distributor,,,always looks tight to me,,but didn't want to do alot of grinding on the VC.
Thanks again wink
Doug
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2262232
03/02/17 04:41 PM
03/02/17 04:41 PM
The tank hardly ever needs to be drained. Usually just gets some condensation in it.
There are no baffles in or under the fittings on the valve covers. Just drilled a hole and welded on the -10an bung. I just made sure the hole was in between the first pair of rocker arms.
I just had to clearance the valve cover a little to clear the distributor, not the cyl. head.
CHIP
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2262253
03/02/17 05:30 PM
03/02/17 05:30 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I love the way most pics show the logo milled off on the valve covers. I did mine also, as well as the intake.
Re: INDY valve covers/breather/MSD dist questions [Re: Airwoofer] #2262261
03/02/17 05:55 PM
03/02/17 05:55 PM
LOL, yep. Mine had the logo when new, but I set them up on the DCM head surfacer and cut em smooth. Wish I had a milling machine to smooth out the manifold too.
CHIP
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2262272
03/02/17 06:35 PM
03/02/17 06:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You can buy them with no logo !!
Re: INDY valve covers/breather/MSD dist questions [Re: 69CHARGERMD] #2263561
03/05/17 05:07 AM
03/05/17 05:07 AM
Australia
P
P
Australia
Nice motor shot !!!
Doug smile
No, its a little tight like everyone elses but no biggie
