Need a pic of carb dash pot installed #2257996
02/23/17 12:39 AM
02/23/17 12:39 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I just got a dash pot and bracket for the AVS carb for my 69 Coronet R/T 440 4 speed, it was missing off the carb, does anybody have a pic of one installed and how it interacts with the linkage?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2258007
02/23/17 12:59 AM
02/23/17 12:59 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi bee,i just did one on a 69 440 4 speed coronet. will post pics for you.ronnie
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2258009
02/23/17 01:03 AM
02/23/17 01:03 AM
cbusters Offline
cbusters  Offline
There is also a lever on the throttle shaft.
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2258015
02/23/17 01:12 AM
02/23/17 01:12 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's one, 68-69 Hemi 4 speeds and 69 AVS 54 speed cars had these. Hemi and AVS versions had unique brackets and engagement arms but they work the same.
Re: Need a pic of carb dash pot installed [Re: ScottSmith_Harms] #2258020
02/23/17 01:16 AM
02/23/17 01:16 AM
Dreaming of the 808
Dreaming of the 808
Scott, I think I'm missing that arm, are you still restoring these carbs?
Re: Need a pic of carb dash pot installed [Re: 1969ronnie] #2258023
02/23/17 01:16 AM
02/23/17 01:16 AM
Dreaming of the 808
Dreaming of the 808
Thank you
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2258029
02/23/17 01:27 AM
02/23/17 01:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, looks like you are missing the arm.
Yes, absolutely! Still in the carb business.
Re: Need a pic of carb dash pot installed [Re: ScottSmith_Harms] #2258045
02/23/17 01:52 AM
02/23/17 01:52 AM
Dreaming of the 808
Dreaming of the 808
I will PM you, do you have an arm?
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2258069
02/23/17 02:52 AM
02/23/17 02:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I might, will need to look
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2259105
02/25/17 04:24 AM
02/25/17 04:24 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I know well the dash pot was on '68 - '69 4-bbl 4-speeds, because I have one.
But I was never happy with that throttle action, the long delay in going to idle, and I took it off pretty soon after I took delivery of the car.
Apparently a lot of people didn't like them and took them off, which is why there is a restoration demand for them nowadays.
This is just to say, if you're in the market for a dash pot, you might not like it after you install it either. One solution might be to install it for original looks but make it inoperative.
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2259256
02/25/17 02:18 PM
02/25/17 02:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Dave, ( only) if Scott can't help,let me know.
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2259303
02/25/17 04:02 PM
02/25/17 04:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Go ahead with Bill Dave, I dont have a spare AVS version on hand at the moment up
Re: Need a pic of carb dash pot installed [Re: ScottSmith_Harms] #2259492
02/25/17 10:29 PM
02/25/17 10:29 PM
Dreaming of the 808
Dreaming of the 808
I feel like an idiot, I had the wrong carb sitting on the 440, I dug the correct carb out and it has the arm on it,
Scott, this is the carb I'm going to send you, correct number and date code for my car
Re: Need a pic of carb dash pot installed [Re: AZ_A12_BEE] #2259517
02/25/17 11:09 PM
02/25/17 11:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool, alls well that ends well smile
