Need a pic of carb dash pot installed
#2257996
02/23/17 12:39 AM
02/23/17 12:39 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I just got a dash pot and bracket for the AVS carb for my 69 Coronet R/T 440 4 speed, it was missing off the carb, does anybody have a pic of one installed and how it interacts with the linkage?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Need a pic of carb dash pot installed
[Re: ScottSmith_Harms]
#2258020
02/23/17 01:16 AM
02/23/17 01:16 AM
AZ_A12_BEE
Dreaming of the 808
Here's one, 68-69 Hemi 4 speeds and 69 AVS 54 speed cars had these. Hemi and AVS versions had unique brackets and engagement arms but they work the same. Scott, I think I'm missing that arm, are you still restoring these carbs?
37 Plymouth PU
[Re: 1969ronnie]
#2258023
02/23/17 01:16 AM
02/23/17 01:16 AM
AZ_A12_BEE
Dreaming of the 808
hi bee,i just did one on a 69 440 4 speed coronet. will post pics for you.ronnie Thank you
37 Plymouth PU
#2258045
02/23/17 01:52 AM
02/23/17 01:52 AM
AZ_A12_BEE
Dreaming of the 808
Yes, looks like you are missing the arm.
Yes, absolutely! Still in the carb business. I will PM you, do you have an arm?
37 Plymouth PU
[Re: AZ_A12_BEE]
#2259105
02/25/17 04:24 AM
02/25/17 04:24 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I know well the dash pot was on '68 - '69 4-bbl 4-speeds, because I have one.
But I was never happy with that throttle action, the long delay in going to idle, and I took it off pretty soon after I took delivery of the car.
Apparently a lot of people didn't like them and took them off, which is why there is a restoration demand for them nowadays.
This is just to say, if you're in the market for a dash pot, you might not like it after you install it either. One solution might be to install it for original looks but make it inoperative.
[Re: AZ_A12_BEE]
#2259256
02/25/17 02:18 PM
02/25/17 02:18 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Yes, absolutely! Still in the carb business. I will PM you, do you have an arm? Dave, ( only) if Scott can't help,let me know.
#2259492
02/25/17 10:29 PM
02/25/17 10:29 PM
AZ_A12_BEE
Dreaming of the 808
Go ahead with Bill Dave, I dont have a spare AVS version on hand at the moment I feel like an idiot, I had the wrong carb sitting on the 440, I dug the correct carb out and it has the arm on it, Scott, this is the carb I'm going to send you, correct number and date code for my car
37 Plymouth PU
