i know this has been asked before, what is required to #2253384
02/14/17 04:16 AM
02/14/17 04:16 AM
CA
David Lee Offline OP
CA
convert to larger front brakes on a 67 cuda?
Ah...so many pedestrians, so little time...
Re: i know this has been asked before, what is required to [Re: David Lee] #2253394
02/14/17 05:06 AM
02/14/17 05:06 AM
It depends on what size your talking about taking off and if your converting from drums to disc brakes or not shruggy
If your switching from 9 inch drums to the later model(1973 to 1976) A body disc brakes with the big bolt pattern you will need the upper and lower control arms with the ball joints, spindles and all the brake mounting brackets, hardware and disc and calipers mounting bolts and switch to a proper size for your car disc brake master cylinder thumbs I did this on my 1971 Duster with the early small bolt pattern disc brakes, I swapped the passenger side to the drivers side on the later model caliper mounting brackets and brake calipers to get that heavy weight single piston caliper behind the spindles up scope
Re: i know this has been asked before, what is required to [Re: David Lee] #2253396
02/14/17 05:17 AM
02/14/17 05:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What exactly would you like on the car? What part of California are you in?
Re: i know this has been asked before, what is required to [Re: David Lee] #2253398
02/14/17 05:31 AM
02/14/17 05:31 AM
CA
CA
i want to switch to the larger later date drum brakes
Re: i know this has been asked before, what is required to [Re: David Lee] #2253401
02/14/17 05:38 AM
02/14/17 05:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Why do you want front drum brakes?
Re: i know this has been asked before, what is required to [Re: Morty426] #2253405
02/14/17 06:01 AM
02/14/17 06:01 AM
CA
CA
lighter for drag racing
Re: i know this has been asked before, what is required to [Re: David Lee] #2253570
02/14/17 03:42 PM
02/14/17 03:42 PM
Are you wanting to swap to the bigger 10 inch A body brakes or the bigger B body drum brakes? Either way I'm not sure what you need to do that swap either way confused Sorry.
If your wanting the lightest weight front brake on your car one of the after market racing front disc conversion kits with aluminum calipers may be lighter than any of the stock drum brakes set ups scope
I have a 1965 dart 270 that I bought a front disc brake conversion for the stock nine inch brake front spindles from Strange Engr. scope I haven't weighed them against the stock brakes yet due to the car still being under construction and I haven't mounted all the front brake parts yet shruggy
The car was a shell only when I bought it with boxes and boxes of parts, it came from Santa Barbara, CA so there is no rust on it to fix or body work to have done boogie
Re: i know this has been asked before, what is required to [Re: Cab_Burge] #2253630
02/14/17 05:19 PM
02/14/17 05:19 PM
CA
CA
then 10 inch A body brakes, i swapped out the old rear for an 8 3/4" rear. This going to be a stocker running in K/SA. if this was going to be a ss car or car with a big block I would go the disk brake route.
Re: i know this has been asked before, what is required to [Re: David Lee] #2253654
02/14/17 06:33 PM
02/14/17 06:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's probably better to bite the bullet and get the Wilwood stuff. It will work a LOT better with your linelock and nose dives at the stripe.
Re: i know this has been asked before, what is required to [Re: Jim_Lusk] #2253669
02/14/17 07:10 PM
02/14/17 07:10 PM
CA
CA
I am in the redondo area.
Re: i know this has been asked before, what is required to [Re: David Lee] #2253686
02/14/17 08:13 PM
02/14/17 08:13 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
This should get what you want...
'73-'76 A body upper control arm, doesn't have to be disc, drum is the same
'66-'70 B body spindle with 10" brakes (11" will work also)
both are common parts and should be easy to source
Lots of advantages
-5x4.5" vs 5x4" pattern
-10"x2.5" vs 9x2" / 10x1.75"
-less $$$ than aftermarket discs
-repair parts from the local parts store
ditch the adjusters so you can adjust the brakes for zero drag
the big '66-'69 11x3" brakes didn't have them to start with
Re: i know this has been asked before, what is required to [Re: David Lee] #2253702
02/14/17 09:04 PM
02/14/17 09:04 PM
are you staying SBP? some ceramic or velvetouch shoes or haveing a brake specialty shoes rivet on some killer lining material might give you the extra bite you need & not add any weight.
Re: i know this has been asked before, what is required to [Re: David Lee] #2253833
02/15/17 12:38 AM
02/15/17 12:38 AM
CA
CA
thanks very much, exactly what I was looking for.
Re: i know this has been asked before, what is required to [Re: RapidRobert] #2254214
02/15/17 08:48 PM
02/15/17 08:48 PM
CA
CA
no i am going to the higher performance pads, do not want to end up in the sand
Re: i know this has been asked before, what is required to [Re: B5 Bee] #2254594
02/16/17 02:47 PM
02/16/17 02:47 PM
CA
CA
Quick question I found a set of 1973-76 Large Ball Joint Upper Control Arms. Will those work without any problems?
Re: i know this has been asked before, what is required to [Re: David Lee] #2255086
02/17/17 04:28 PM
02/17/17 04:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, if you're going the way B5 Bee recommended.
Re: i know this has been asked before, what is required to [Re: Jim_Lusk] #2255300
02/18/17 01:09 AM
02/18/17 01:09 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I did the disc brake change as Cab did but didn't switch sides, seems that extra weight of the calipers really doesn't matter on my Barracuda. Payed $100. bucks for everything and bought new pads.
